Engine fan continues to run after car is shut off
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by newenegue, Jan 5, 2012.
  1. newenegue
    newenegue New Member
    Aug 30, 2011
    14
    2012 Golf TDI
    Recently I have noticed the engine fan (mounted at front of the car) continues to run for several minutes after I shut the car off. The coolant temperature seems to run normally at the middle of the temperature gauge. The fan shuts off automatically after about 5 minutes. Is this normal?
    Also, is it weird that our speedometer reads in 5mph increments until 80mph then switches to 10mph increments? :dunno
  2. Keithuk
    6,907
    Yes this appears to be normal I've heard my fan running 2 or 3 times after I've switched off but I don't know why that is.
    They say its doing a DPF regen so it keeps the engine cool but if the engine is switched off it not producing heat so why does it need extra cooling?
    I think the has been talked about before on here if you search.
  3. Conrad -JSW
    Conrad -JSW Member
    Dec 11, 2011
    103
    2012 JSW TDI DSG Sunroof/Nav Silver/black
    Northern Illinois
    If you shut your car off during the regen cycle the cycle is aborted. The fan runs a bit to cool off the system and it's perfectly normal. No worries.
  4. vdubdezl
    vdubdezl Member
    Aug 27, 2011
    74
    06 JETTA TDI 5MT, 05 HONDA ODYSSEY EX-L
    SC
    He's right! :+1
  5. 2011GolfTDI
    2011GolfTDI Member
    Oct 8, 2010
    219
    2011 Golf TDI DSG
    Virginia
    In the 15 months I've owned my TDI, I think the running fan at shutoff has happened 4 or 5 times.
  6. Conrad -JSW
    Conrad -JSW Member
    Dec 11, 2011
    103
    Northern Illinois
    I've had mine for just over two weeks and it's happened twice already, both times in my garage.
  7. TDI ATL
    TDI ATL New Member
    Feb 17, 2012
    7
    2012 VW Golf TDI 6M 2Dr
    This happened to me once. I've had my 2012 Golf TDI for about 2 weeks. I was in my office parking lot so I turned the car back on and drove it to another parking space. When I turned the car off again, the fan shut off. I'm a little concerned about this because when this happened in my 2002 MINI Cooper the entire fan unit had to be replaced. Also caused the battery to die.
  8. Keithuk
    6,907
    Well with our 2008 Seat Leon 1.9 TDI BLS at work the fan runs all the time hot or cold. ;)
  9. Conrad -JSW
    Conrad -JSW Member
    Dec 11, 2011
    103
    Northern Illinois
    It's 100% normal, do not worry about it.
    http://www.myturbodiesel.com/1000q/DPF-Adblue-FAQ-VW-Audi.htm
    I'm VERY surprised that Keithhuk, being a mod here, didn't know what this was.
  10. jimjay
    jimjay New Member
    Aug 9, 2011
    27
    VW NB TDI AGR 98 5spd
    My fan will run in the summer when it is hot(>100 F air temp) and I have been in stop and go traffic, if I have been driving at speed then stop the car it rairly runs.
  11. Cogen Man
    Cogen Man Active Member
    Jun 27, 2011
    439
    Golf TDI/2011
    Kingston, Ontario, Canada
    Window tint, window vent visors, ScanGauge II.
  12. sps333
    sps333 New Member
    Dec 12, 2011
    Golf/2012
    Regen---thanks!
    This answered my question about the hot smell in the garage and the supersonic fan speed. Thanks, everyone. I almost don't miss my MK IV Golf, but the 1.8T was a lot of fun.
  13. SFR709
    SFR709 New Member
    Jun 27, 2012
    Jetta/2006
    Would a 2006 jetta tdi pd have the same dpf system you spoke of? My fan is actually doing the same thing.
  14. d2305
    d2305 New Member
    Apr 29, 2012
    24
    2012 Jetta
    No, you may have a problem if they don't shut off.
  15. SFR709
    SFR709 New Member
    Jun 27, 2012
    Jetta/2006
    Does anyone have any idea what would cause this? It's only the larger primary engine cooling fan that keeps going for around 10 seconds after the engine is shut off, I havn't seen the the secondary turn at all, but I'm not sure if the engine is getting hot enough to engage it. Would a busted secondary fan cause an increase in current and cause the primary to keep running?
  16. 510808surfskate
    510808surfskate New Member
    Jul 11, 2012
    golf 2003
    stock.
    i think the fan staying on is suposed to happen
  17. fastson
    fastson New Member
    Apr 10, 2012
    18
    2013 1.6 TDI BMT
    I've got a question regarding the fans running during an interrupted regen. Do they stay on for several minutes and are they very loud?
    My fans have been on during hot days (73F+, yes that is hot for me. :p) but only for about 20+30 seconds or so after turning the car off. The fans weren't really loud either.
    So regen: About how many minutes(?) and very loud fan noise/high speed?
    My car has only gone about 500 miles in total since I got it (10 days ago), and it has reached operating temperature (oil temp: ~212F) each time, it should have done some passive regeneration as I do some hard accelerations up to highway-speed and some overtaking, I doubt it has done any active regens yet (my understanding is it will do one whether the filter needs to be cleaned or not, it does them at certain set intervals).
    I just want to know what the signs are for a active regen if I ever interrupt one.
  18. mrmmacd77
    mrmmacd77 New Member
    Jun 26, 2012
    47
    2012 VW Jetta Premium
    I've answered some of your questions below... Hopefully if I'm wrong somebody will step up and help me to understand further.. but most of these come from reading a lot of forums on this exact topic.. and my own experiences..
    Normal... 20 to 30 seconds for a semi warm day based on driving habits... No regen interrupt occurred.
    Depending on if you interrupted the regen... fan speed 100% very loud.. stays on for quite some time ~5minutes or more depending on how hot the exhaust was prior to shutting down the motor.
    Negative, IIRC, it reads the soot load from the sensors in your ECM... Having a heavier foot is actually better for your DPF then lugging the motor... Your EG temperatures are higher the harder you drive so you get more burn off the natural way. Your ECM will adjust accordingly and only force a regen when it is needed.
    Fans will be on 100% regardless of road speed... The OB computer will slightly bump your boost lvls to compensate for the loss in power do to the regen occuring... if you pull into a parking spot and your fans are going full on... engine speed will be 900~950rpms at idle.. there's a very good chance you are in the middle of a regen.. May notice a bumpy idle at a redlight or stop sign... (usually only if it goes into a regen immediatley following a cold start... I've noticed this last one less and less the more miles I've put on the car... Regens were pretty aggressive for me in the beginning less than 2000 miles..
    Above all drive more worry less... Interrupting a regen isn't the end of the world and most people will probably not even notice an active regen occuring anyways..
  19. fastson
    fastson New Member
    Apr 10, 2012
    18
    2013 1.6 TDI BMT
    mrmmacd77: Thanks for the detailed response. :)
    Drive more worry less, I try to live by that. :) Its just with a new car I want to have all the facts.
    I figured hard accelerations would help clear out the DPF so I try to do that each time I get/merge on the highway (the other occupants of the car don't always appreciate that though, but that's not my problem. ;) )
  20. mrmmacd77
    Jun 26, 2012
    47
    Yeah my gf thinks I wait until she starts her makeup to stomp on it... I swear I don't do it on purpose.... :laugh:
    Glad some of that helped ease your mind... On average I've noticed mine regening around 500-800miles... or usually about once per tank...
