engine connecting rod bolts
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by windygap man, Mar 31, 2011.
  1. windygap man
    windygap man New Member
    Mar 3, 2011
    8
    vw 2005 tdi
    I have 2001 jetta tdi and the pan got hit. Oil all out on ground. I pulled #3 rod to see damage, looks pretty good, only minor polish, but can I reuse the rod bolts, they look like tourque and turn bolts with reduced shoulder.:bowdown
  2. Lhonk
    Lhonk New Member
    Aug 20, 2007
    74
    No, better not.
  3. chittychittybangbang
    23,757
  4. almir
    almir Member
    Feb 6, 2011
    664
    2005 jetta tdi gls 1.9
    Chicago
    next time make sure your jetta wears panzer plate over her belly.
  5. napierdeltic
    napierdeltic New Member
    Mar 4, 2012
    2000
    Hello TD "wizards", I'm new here, and probably as "weird and eccentric"
    one can get after wrenching (hobby/enthusiast) for 45 years. I've owned
    nearly every make but Yugo and Citroen, including some aircraft. Here goes:welcometomyturbodies
    I just bought a 2000 Beetle TDI (125k) with oil pan destruction history in
    the maintenance records. The engine runs fine but with a annoying
    clatter at all RPMS. Drained oil and waved a strong magnet through the
    catch bucket, looking for metal...did not find anything. Thought maybe
    the bearing shell had not worn down to the base, so I pulled ALL rod
    caps and inspected...crankshaft journals looked "new" and inserts were
    fine, only checked the lower portion, which SHOULD be indicative of
    condition. I'm "on the fence" regarding reusing the rod bolts. I've
    always reused TTY rod bolts in the past, but generally replaced tty
    head bolts. My logic is this, while turning the bolt to the 90 degree
    matchmark, the turning force should not decrease up to the stopping
    point. Of course, prior to installing the bolts, a cleaning and inspection
    of the bolt, comparing bolts to one another for uniform length, lubing
    them, and the install. If during installation, a perceived torque "drop off"
    happens, then the bolt has been stretched beyond it's clamping range.
    Mercedes gives the rebuilder stretch allowance data on some of their
    critical fasteners, i.e. head bolts.
    My hunch now is the "clatter" is either an injector problem or a cam
    follower/bucket leaking down. I'm definitely fabbing a skid plate for
    the car, maybe also replacing the front springs to gain clearance.
  6. chittychittybangbang
    23,757
    rod bolt: VW# "028 105 425 c" $3.36 each, 8 required ;)
    Other noise possibility other than what you mentioned is loose flywheel.
  7. napierdeltic
    Mar 4, 2012
    2000
    "CCBB", Is that the current VW dealer price?
    Thanks! (will check flywheel)
