EGR valve bypass performance pipe
Discussion in 'General Diesel Discussion' started by ksbigair, Feb 24, 2012.
  1. ksbigair
    ksbigair New Member
    Feb 24, 2012
    2000 Jetta TDI 1.9
    I put in a performance pipe by diesel-geek that bypasses the egr valve completely over a year ago on my 2000 tdi jetta and as they told me, I constantly get a P3130 code. I have a scan gauge that I use to reset it all the time. I was wondering if anyone had any fixes to bypass this code? An inexpensive programer that I can use to turn this code off, ect.? Any help would be appreciated. Thanks.
    23,767
    You've changed the emissions of the car and it knows something is wrong. You must reflash the ECU to remove the EGR system with no codes.
  3. ksbigair
    ksbigair New Member
    Feb 24, 2012
    2000 Jetta TDI 1.9
    I did a search on re-flashing the ecu and really didn't find anything. Is this something that a dealer has to do or is there a way I can do this? Thanks
  4. chittychittybangbang
    23,767
    dealer can't do since it violates emissions and they are not equipped or knowledgeable to do this kind of modification.
    Contact kermatdi.com and malonetuning.com, they do ECU reflashes. It can't hurt to also get a performance tune while you're at it :)
  5. ksbigair
    ksbigair New Member
    Feb 24, 2012
    2000 Jetta TDI 1.9
    Thanks, I will give them a look!
