DIY: Clear (or smoked) side markers on MKVI Golf / JSW / TDI
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by sfpegasus, May 23, 2011.
  1. sfpegasus
    sfpegasus New Member
    May 23, 2011
    41
    MkVI Golf TDI 2DR
    Clear side markers look especially cool on a candy white car!
    [​IMG]
    Tools needed:
    1. T25 Torx screwdriver / bit
    2. Patience
    The side markers must be removed from inside the front wheel well liner. Do not attempt to remove your side markers using the MkV method of pressing on the forward edge. It will not work and will probably only serve to detach the housing from inside the bumper cover. Trust me. I spent several hours gluing a housing back in place.
    It is not necessary to remove the wheel or jack up the car. Simply turn your wheels all the way to the right if you're working on the left side of the car, or to the left if you're working on the right side of the car.
    Remove the three screws on the outside edge of the wheel well liner.
    [​IMG]
    Prop open the wheel well liner so you can get your hand inside. I used a roll of tape.
    [​IMG]
    The side marker has a clip on the rear edge shown on the right hand side of the picture. Push it towards the front of the car and the marker will release from the housing.
    [​IMG]
    The electrical connection pulls straight off. Now's a good time to change your bulb if you want amber lighting.
    Reinstall the electrical connector on the new side marker. There are some alignment marks on the rubber boot that need to be lined up with the alignment marks on the plastic housing.
    Reinstall the new side marker by inserting the forward tab in the housing and snapping the rear firmly into the housing. I suggest you hold the housing from inside the fender as you do this. It doesn't appear these things are too firmly attached to the bumper cover.
    Reinstall the three torx screws in the wheel well liner.
    [​IMG]
    Believe it or not, I'm using an amber bulb here. Gotta love cell phone pics.
    [​IMG]
    23,900
    :thumbsup
    I will add this to the FAQ. It will also qualify for the writeup contest even though it's very simple.
  3. Keithuk
    7,074
    Yes I've seen these on US cars only, usually amber?
  4. sfpegasus
    May 23, 2011
    41
    MkVI Golf TDI 2DR
    Yeah, for all the years I've driven, I just found out that you guys across the pond don't have these.
  5. sway162
    sway162 New Member
    Aug 19, 2011
    6
    2012 VW Sportwagen TDI DSG
    Thanks for posting this! Quick noob question.....where do you pick up clear sidemarkers?
  6. sfpegasus
    May 23, 2011
    41
    MkVI Golf TDI 2DR
    Parts4euro.com is where I got them
  7. sway162
    sway162 New Member
    Aug 19, 2011
    6
    Great, thanks!
  8. abv36
    abv36 New Member
    Sep 6, 2012
    4
    VW Jetta 2006 TDI
    How to easy replace side markers on Mk-5 Jetta 2006
    Sfpegasus,
    You, don't have to disassemble the front wheel well liner(s) in order to get access and replace
    these side marker lights. (I have done this on 'Jetta 2006 TDI Special Edition')
    There's much easier way to do that - I have discovered it accidentally.
    From the front side of the car, remove left (and/or) right cover(s), located below the headlights
    - both are held by a single Phillips screw, then pull these covers off and they will snap easily out.
    (You can find more detail instructions as how to remove these 'covers' in your car manual,
    see the section for 'towing' - where it describes how to remove the (passenger side) cover - and
    screw in the 'eye tow' bolt (anti-clockwise rotating direction).
    Once you remove these cover(s) off - you can 'relatively' easily gain access to the sockets of these
    bulbs, see which direction they go and gently pull them out. Replace the bulbs and re-insert back.
    Then snap back the cover(s) and tighten them back with the screws. You're ALL Done NOW !
  9. deserthi
    deserthi New Member
    Jun 7, 2013
    Golf tdi/2010
    What bulb do we need. I don't have my book with me and my left light is burned out.
    thanks
  10. abv36
    abv36 New Member
    Sep 6, 2012
    4
    VW Jetta 2006 TDI
    #194 , you can buy it from WalMart
