Different 3.0 TDI on 2011 Audi?
Discussion in 'Audi Q5, Q7, Touareg TDI, Porsche Cayenne forum' started by wensteph, Dec 11, 2010.
  1. wensteph
    wensteph Member
    Aug 31, 2010
    32
    2011 Touareg TDI
    Chittychitybangbang, there was an older post somewhere mentioning a new engine with only 2 timing chains and speculation it might be Audi only since the engine codes for VW remained the same. Do your sources show any more information? Idle curiosity only.
    23,767
    No, the newer 3.0L engine is only showing up for Euro Audi Q7. The North American Audi and Touareg are showing the same engine, to the best of my knowledge.
  3. wensteph
    wensteph Member
    Aug 31, 2010
    32
    2011 Touareg TDI
  4. chittychittybangbang
    23,767
    That's probably just for the European engine. The US spec engine for 2011 is still showing 225 hp.
  5. grn04
    grn04 New Member
    Aug 14, 2007
    139
    How does 32 mpg compare to the current engine? A loss of 20 horsepower isn't that much since the torque is so important in a heavy car and if it really improves mpg it could be worth it.
  6. wensteph
    wensteph Member
    Aug 31, 2010
    32
    2011 Touareg TDI
    I thought this new engine was only available in the Euro Q7.
    This new engine is down 74 foot pounds. 332 vs 406.
    Audi shows 17 city, 25 highway, 20 combined for the US TDI, but the European milage figures are computed in a different way so you don't know if you're comparing apples to apples.
    This engine also looks to be about a half second slower to 60. The attached Audi press release mentioned a very complex cooling system with separate water jackets for the block and heads and reduced spring tension rings for lower friction to increase mpg. I don't like the idea of reduced spring tension on diesel rings at all; maybe if they had a longevity reason, but not just to eek out a percentage of a mpg.
    After reading this I'm happy they didn't drop this one into the US versions.
