Crack and spun flywheel
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by CKEYSER, Dec 27, 2010.
  1. CKEYSER
    CKEYSER New Member
    Dec 26, 2010
    2002 TDI JETTA
    I'm in the process of doing a flywheel and clutch job on my 2002 jetta tdi, and when i dropped the transmission i noticed the flywheel center was crack and spun so i can't get to the flywheel bolts. Does anyone have any sujestions on how to get to the bolts? Thanks in advance. Oh the clutch is a sachs clutch with 170500miles
    23,757
    Do you mean it's covering the bolts? If you can't pry it to turn then you have to cut away material to get access to the bolts. Does it look like this:
    [​IMG]
  3. Genos
    Genos Member
    Sep 29, 2010
    39
    7/2013 Passat Sel Premium & 97.7 TDI Jetta
    Spanaway Wa
    Gt wing & GTI Flyer wheels. on '97 Mk3
    I've had that happen at wrk, just used a pry bar& moved it enough to get socket on. cheers Genos
  4. CKEYSER
    CKEYSER New Member
    Dec 26, 2010
    2002 TDI JETTA
    Thanks for the tip, I tried to pry on it but I was afraid to pry too hard so i just cut the metal off that was covering the bolts. no problem after that. thanks again GENOS! now to tackle the rear seal.
