Cost to replace timing belt
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by Jeff04TDI, May 18, 2011.
  1. Jeff04TDI
    Jeff04TDI New Member
    Mar 9, 2011
    51
    04 VW Golf TDI
    What is a fair cost to replace the timing belt? 2004 TDI.
    Jeff
  2. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,089
    Jetta 2003, Golf 2001
    Passat or Jetta/Golf/New Beetle? Be sure that the water pump, tensioner and idler are also replaced...
    Are you doing the going to a dealership, private garage, or a TDI-Specialist (many of those are referred-to as "Gurus" over on the TDIclub)...
    Please go over the procedure that's outlined in the 1000q "how To" section here so that you can ask the proper questions... (such as what lockdown tools they use...)
    Dealership will be the most expensive, naturally, possibly around $1000... An independent could charge around $500...
    Closest TDI-Specialist to you known to me would be in Davidson...
    Yuri
  3. Jeff04TDI
    Mar 9, 2011
    51
    04 VW Golf TDI
    What do these gurus do?
    Jeff
  4. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,089
    It's a term that has sort evolved to describe those mechanics who have a record of performing (mostly) timing belt changes in the proper manner, without taking shortcuts... Some operate garages, some work out of their homes, some do this full-time, some only on weekends. The bottom line is that they'll use (or recommend for you to buy) a complete kit of parts - many dealers and garages leave out components or bolts, not to mention that many old-time VW "specialists" don't lock down the engines but use what has become to be derisively called "mark and pray"...
    Yuri
  5. dezel
    dezel Member
    Jan 5, 2011
    157
    02 jetta tdi leather gls
    Kerma chip & Bosio 520 nozzles
    Guru - A spiritual leader of Hinduism. A vw guru -- Chitty of coarse !!
  6. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,089
    For sure, the force behind this wonderful website is a TDI guru... I didn't know that he works on other people's cars, as he's never made it obvious...
    Yuri
  7. schimmerb
    schimmerb Member
    Oct 19, 2010
    54
    2006 Jetta TDI, 130k+ miles, 5spd
    Stroudsburg, Pa
    In my area, metro NY, dealer was $1400. From this forum, found a great mech and got it done for $700. Also, the dealer would only do the 60k kit and the mech did the 100k kit.
  8. Jeff04TDI
    Mar 9, 2011
    51
    04 VW Golf TDI
    New here so I don't know. But .... where is the list of gurus? What are the criteria for getting on it? Could someone who is not on it do just as well?
    I got a reasonable quote (650 to 700 incl w/p) from a local garage whom a close friend trusted with her VW for years. What questions would you guys ask them before letting them work on my car?
    Thanks for your very helpful input. Great forum. I've just never neede to do much work on my VW Golf TDI!
    Jeff
  9. chittychittybangbang
    23,757
    Hey thanks, I'm not a guru, I just document everything I do which makes me seem more experienced than I really am.
    Hey thanks, it does take a bit of work to keep the website updated and add more material. I do not work on anyone else's car but will sometimes help someone else do a complex job. Te level of knowledge by the true gurus is far greater. The trick is getting you guys to share it :)
    You could print out the DIY and ask them to review it. That price is good. There's a list of mechanics on TDIclub but since it's based on user recommendations, your mileage may vary. I have been reluctant to start a list for two reasons.
    One, a recommend shop local to me didn't know what they were doing based off their inability to fix an extremely common problem but got a recommendation. There are other gurus who are quite competent but are guys working out of their garage with no insurance and no license.
    Two, for legal reasons, I do not want to publicly recommend any mechanic unless they are a real business. Therefore, any list of recommended mechanics would have to be created and maintained by forum users which goes back to problem #1: How to verify the quality of their work to ensure the high standards of the list? They could get lucky or have a bad day, and the customer often doesn't know if something was done right or not.
  10. Jeff04TDI
    Mar 9, 2011
    51
    04 VW Golf TDI
    Awesome info! I can understand your reluctance to make a list.
    Is it appropriate to ask Yuri for the contact info of the TDI guru he mentioned above, who works out of Davidson?
    Jeff
  11. tdiguy27
    tdiguy27 New Member
    May 20, 2011
    2002
    timing Belt replacement
    dealers are almost always higher than independent automotive shops I would say a good price for a shop is $ 500.00 - $ 750.00 parts & Labor most dealers would charge more than that........
  12. samiam63
    samiam63 New Member
    Apr 14, 2012
    2006 jetta tdi
    timing belt replacement
    know anybody in n.w. ohio or n.e. indiana that does good work ata fair price?
  13. vertbus
    vertbus New Member
    Apr 16, 2012
    beetle 05
    About 1,100.00 in Oklahoma includes parts.
  14. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,089
    Sounds like a dealership price... if you happen to be driving to Dallas or Tulsa you can get high quality work done for a lot less...
    Yuri
  15. Hoff6282
    Hoff6282 Member
    Apr 6, 2012
    57
    2000 Volkswagen Golf TDI ALH
    Brighton, MI
    Egr delete, lift kit, skid plate, pp520 nozzles
    I'd say if you can get it done for $500, I'd jump at that. I just replaced the timing belt on my 2000 Golf and I paid $180 for the parts plus $230 for the appropriate locking tools, so that right there is already north of $400. If you factor in the amount of time it takes you to perform the whole task, the other tools you'll need if you don't already have them, and the possibility that you might goof up and have to start over (which I did), honestly anything below $700 or $800 seems pretty fair to me.
    In the end though I was able to do it successfully, and I'm glad I did because I learned a lot. Having this site to use as a resource was immensely helpful though, and again, I thank you guys. If you are mechanically inclined and time isn't necessarily pressing you, you might enjoy doing the job yourself.
    Whichever route you decide to take, good luck with your vehicle Jeff!
  16. DAVEP
    DAVEP New Member
    Apr 2, 2013
    JETTA,2006
    Davep
    jeff, let me know what cost you incurred for your timing belt and related parts.
    Thanks
  17. DAVEP
    DAVEP New Member
    Apr 2, 2013
    JETTA,2006
    What is the reasonable cost for timing belt, water pump and related parts? Let me know - thank you
  18. chittychittybangbang
    23,757
    davep, read the BRM PD timing belt article in the mk5 FAQ. You posted in the mk4 FAQ, they are talking about a different engine. There's links to parts vendors where you can look at prices. Don't buy super super cheap parts because they'll be the made in China ones...
  19. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,089
    There are things that need checking in addition to simply replacing the belt(s), tensioner, water pump and idler on your car. This model (BRM engine) is known for wearing out the camshaft and lifters, which may raise the price substantially.
    For a procedure that only has to be performed every 80 - 100,000 miles, price or convenience shouldn't be the overriding factor... just get it done properly! I initially thought you were in Redmond, WA... there's a very good TDI specialist shop there... in your case, I don't know of anyone closer than Portland I would trust with this... sorry...
    All the best,
    Yuri
  20. DCi
    DCi New Member
    Sep 10, 2014
    14
    VW Passat TDI SE 2012
    Des Moines, Iowa area
    Sorry to bump an old thread, but I need advice. I purchased a 2012 Passat SE TDI just about 3 weeks back. It is high mileage and will break 100,000 on Friday. I don't want to risk damaging my daily driver, so I am looking to get the timing belt replaced soon. I'm in the Des Moines, IA area. I've got a dealership and an independent (large) European auto specialist in the area. The independent quoted $1200 for the TBelt w/water pump. I'll have a price tomorrow from the dealership. Are there other options in the area that I could consider?
