Coolant Smell
Discussion in '2012-2016 VW Passat TDI forum' started by ancnfamily, Jan 23, 2012.
  1. ancnfamily
    ancnfamily New Member
    Nov 5, 2011
    24
    2012 Passat Tdi comfortline
    So after driving my 2012 Passat TDI and parking it in a garage I can smell a bit of engine coolant. When I check level when hot it seems to be ok and it does not change. Had a dealer look at it and they said that everything is ok and they can't find any issues. Smell seems to be stronger on the drivers side of the engine. Does anyone of you smell coolant and should I be worried about it?
    thanks.
  2. Jim W
    Jim W Member
    Jun 13, 2011
    97
    2011 Jetta TDI
    2011 Jetta-none, 2008 RAM Mega Cab lost the BlueTe
    Hi,
    Is the smell similar to a water vapor smell? Do you smell this all of the time or just once in awhile?
    What you might be smelling is the completion of the Regen cycle. I also use to smell the Regen finishing up on my 08 Ram but the truck lost the Blue-Tec emissions somewhere. Now my wife's Jetta has the same orders when regening.
    Jim W.
  3. ancnfamily
    Nov 5, 2011
    24
    It smells when it gets hot and after each ride. dealer told me it could be vapours due to engine running hot. Smell is on the right side of the engine, and when I smell around overflow tank, there is no smell.
  4. MyAvocation
    MyAvocation Member
    Aug 6, 2011
    254
    Jetta TDI 2006.5
    Sounds like you have a valid issue, but dealer will not be of much help until there are visible signs. My recommendation is to remove the belly (bottom engine cover) to take a close look and be prepared to snap some photos. Definitely do this before your warranty expires.
  5. ancnfamily
    Nov 5, 2011
    24
    I no longer own this car. Around October of 2014, coolant tank had to be toped up every day. Dealer response was that nothing is wrong with the car. After screaming and yelling at them at the dealer they decided to get VW Canada involved. Kind of 3 yrs toooo late. So dealer did what VW told them and issue all along was with intercooler. It was replaced under warranty but car did not feel the same. It had hard time reaching anything above 100 Km/hr....
