Common rail fuel system failures
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by Audi5000TDI, Jul 26, 2012.
  1. Audi5000TDI
    Audi5000TDI Member
    Dec 20, 2010
    109
    2013 touareg tdi
    CA
    ID-10T detector for VW Stealerships
    Owning a 2012 Passat SE TDI, I've often wondered why it was that they didn't experience HPFP failures, with their Gen 2 common rail motors, compared to 2009-2012 modeled jettas, JSW's, Golfs and 3.0 TDI Touaregs.
    Was it the lower pressure of 1800 bars on the pump, versus 2000 on the other models? Nope, could not be, as the Touareg study manual only runs 1600 bar in their V6, and those still fail also... All the models with HPFP failures run Piezo injectors, the Passat runs solenoid injectors.
    Which, to me, isolates the problems with the injectors... as the Touareg also runs adblue, and also runs lower fuel pressures at 1600 bar, but it runs the piezo injectors, and it too fails with HPFP's.
    Today... after years of asking around... something came out that probably wasn't supposed to come out. Piezo injectors are failing.... and when they fail, the little ceramic discs inside, be it due to water in your fuel... the moisture under pressure by the ceramic disks turns to steam and fragments/cracks, grenades the tiny ceramic discs, as does the pressure and temp in there if there is gasoline in your fuel cause something like the gas fuel and it's low vapor pressure to "flash" again cracking the ceramic wafers in the piezo injectors. What you have now is very fine ceramic grounds going thru your fuel system constantly.... they don't pass through injectors, but they pretty much pass around the recycled fuel path from the return lines of the injectors, back to your fuel pump, where they do their abrasive insiduous damage, tearing apart and grinding up into metal bits, your HPFP.
    The solenoid injectors have no such ceramic wafer discs, they don't crack, they don't crumble, they don't put ceramic bits and pieces into a continous loop to grind up and grenade your fuel system.
    And that is why VW and Audi, Ford, and GMC, most likely will abandon piezo injector systems in the North American markets... due to our fuel. We still have problems with North American fuel, and I still recommend some sort of biodiesel blend below B5 for lubricity of at or under 300 micron wear scar, as well as running Power Service White Bottle with every tank of fuel to keep your fuel system dry.
    According to my source, who shall remain nameless, it's failed ceramic from piezo injectors that is wrecking the whole fuel system. Fuel pressure in the HPFP may or may not be an issue at 1600, 1800 or 2000 bar pressure.
    All of the above is just opinion, and may or may not be fact, you be the judge.
    Niner would have posted this on TDIclub, if he still could, but there is a ban happy moderator there that is full of :BS
  2. Cogen Man
    Cogen Man Active Member
    Jun 27, 2011
    439
    Golf TDI/2011
    Kingston, Ontario, Canada
    Window tint, window vent visors, ScanGauge II.
    Very interesting thought. Something to really think about. I have the 2011 Golf TDI. I had my fuel filter changed about a month ago. Only had about 10,000 km on it. The dealership didn't want to do it. I said, so you don't want my money. Okay sell me the filter and I'll do it myself. I wanted to have a look inside the filter housing for any metal bits. They decided to take my money. No metal in the housing and the filter looked good. You could have something with the ceramic on the Piezo's failing. :panic:
  3. chittychittybangbang
    23,900
    IMHO, too many confounding factors. Different revisions of fuel pump, fuel quality variations, etc. Plus, the Passats are all still pretty new. Also, if someone on another board feels strongly about something he's free to post it himself here. I only delete spam/swears/sex/sircular and pointless arguments.
    Good suggestion though. What size of filter could catch these? Also, piezo inj are used with a number of gas cars, why don't they have HPFP failures?
  4. fastson
    fastson New Member
    Apr 10, 2012
    18
    2013 1.6 TDI BMT
    I thought a number of BMW models had HPFP problems. No idea what was the cause though.
    If you search on Youtube there are heaps of videos of BMWs with failed or failing HPFP.
  5. Audi5000TDI
    Audi5000TDI Member
    Dec 20, 2010
    109
    2013 touareg tdi
    CA
    If it's the pump that is failing on it's own and not some other mitigating circumstances, we should be seeing failures of HPFP's on solenoid injectored 2012 passat TDI's by now. There should have been at least a few by now, with the heat and summer weather. Time will tell, but if it's isolated to diesels with only piezo injectors, as it is currently...
    Bosch has blamed water in the fuel, and gas in the fuel, they all have much lower vapor pressure than diesel fuel, and if they are causing injectors to fail, then Bosch has a design problem with fuel available in the USA, in their piezo injectors models.
    I would not buy a CR TDI Touareg with what I know today, until VW /Audi begins to use solenoid injectors on that modeled motor. The current piezo injection model only runs 1600 bar pressure. VW is bumping up the horsepower in this motor for 2013, and I wonder when or if they will change to solenoid injectors for the Touareg.
    Or I can hope for a 2013 Tiguan 2.0 TDI for 2013.
  6. MOBI
    MOBI New Member
    Jul 28, 2012
    Ford Focus 2009
    I read with interest your comment on Piezo electric injectors. I have seen tips of nozzle bodies on mechanical injectors blown off due to water in fuel, of course the reason being water expands 1700 times its volume as it turns into steam...........the pressure has nowhere to go so off comes the tip of the nozzle...........fotunately it does not occur very often..........therefore ceramics can certainly breakdown under these conditions.
    If you are having problems with free water in the fuel, look at your fuel filtration system. You can obtain 2 micron or even 1 micron filters that will remove water from your fuel..........fuel filtration is the most impotant system when dealing diesel engines.
  7. Audi5000TDI
    Audi5000TDI Member
    Dec 20, 2010
    109
    2013 touareg tdi
    CA
    Ceramic issues
    Let's go back to Bosch and ceramic tipped glow plugs in the B5 passat of 2004 and 2005... FAIL, and they changed back to steel tipped glow plugs for that model.
    I've run ceramic bearings in wheeled hubs and crank bearings on my mountain bike, and guess what... they failed within a season, whereas I get 2 to 3 seasons out of a set of crank bearings out of carbon steel before they get worn out. Ceramic bearings crumble inside the bearing race.
    Now Bosch has been running ceramic again, in Common Rail diesel injector bodies. You tell me what water or even a pinch of gasoline with it's flash point much, much lower that diesel fuel is going to do inside that very hot injector body getting all it's heat from the combustion, from the cylinder head, from the heat coming up the injector tip into the rest of the injector body?
    When ceramic cracks and fragments, (as it does, ask anyone that's lost a glow plug tip in a B5 Passat TDI) all those bits go back the return fuel line, right back into the filtered fuel side of the fuel filter, to be rerouted straight back to the HPFP, where ceramic, being a lot like glass and sand with silica in it, tears everything else up.
    Watch the 2012 NA Passat TDI with solenoid injectors for the next year for HPFP failures... there is a BIG REASON Bosch takes the injectors and the HPFP together when changing out a fuel system for failure.... and remanufactures them.... Is it the ceramic bits in the injectors that are sh*tting the bed and wrecking everything else? I ask, as a question, I don't have the answers, but you can be damn sure Bosch knows the real reasons....
    We need folks that can get their hands on old CR tdi injectors and open them up and see the conditions of the goods inside after a HPFP failure.... this would explain why some folks have gotten complete fuel systems changed out, the injectors failed, and the pump looks almost perfectly fine, even Dwiesel noted that in a few pump samples he'd seen.
    Is this the smoking gun we've been looking for? Don't rule out failed ceramic piezo injectors as the root cause... and there is no way VW specified that or called that out, that would be Bosch's decision, the ceramic injectors are quite a bit more expensive than the solenoid models. We all know how cheap VW is... and Bosch claiming to make the pump more robust, 3 different times, maybe even a 4th time with them now being made in slovakia... with only minor improvements... Have they done anything to improve the piezo injector bodies with ceramic parts more robust? Or is it all a smoke screen, leading us down the wrong path, barking up the wrong tree? Someone needs to bring this to NHTSA
    s attention to investigate PIEZO INJECTORS being a safety hazard, and to do an Engineering analysis of Piezo injectors which require ceramics just to get the tons of very thin stacked together crystal ceramic wafer discs to respond to 80 to 125v input stimulus to cycle the nozzles.
  8. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,684
    2012 TDI Tech Package 6mt
    Mile High
    Could you point out to me where the injector "return line back to the pump" is? (I don't think there is a fuel return line from the injectors).
    Also if this was happening, as soon as the injector fails, it would throw a CEL or a flashing glow plug light, then failure of the pump shortly after?
    Would all the injector fail nearly at same time?
    How about the fuel samples sent for analysis (due to misfuel or HPFP failure) would all/some show ceramic FOB?
  9. potiron
    potiron New Member
    Aug 15, 2012
    2009 jetta tdi seda
    Thanks for this Audi5000.
    This is one of the few theories that actually makes sense. Is it possible for you to get this info. over to the NHTSA folk who are looking at this issue? Maybe it's pointless, but they might give it a test?
    I'm a new member with a 2009 Jetta TDI that experienced HPFP failure and the $10K fix (under warranty). Also, in that strange purgatory of wanting to buy a new TDI Sportwagen (2012 or 2013) because the TDI is "my perfect ride" - but I'm fuel pump failure freaked. Oh well. Thanks again for the post. I've never seen anything like it on the TDIclub.
  10. chudzikb
    chudzikb Member
    Feb 3, 2011
    434
    05.5 Jetta, 03 2 door Golf
    Lancaster PA
    Are these particles too small for the fuel filter to remove? I would think it would take some time for the ceramic particles escaping the fuel filter to take out the pump? Would not the destruction of the injectors throw some kind of a code before the pump gets trashed? I know there are many wiser than I that will have the answers to this. Somehow, I don't see VW stepping up to help fix the problem. The problem will recede with the next design, which will speak volumes about what the problem actually is with the system.
  11. dweisel
    dweisel Member
    Dec 11, 2009
    124
    09 tdi Jetta Sedan-09 tdi Jetta SW-03 tdi Beetle
    dweisel's stainless fuel sending rods
    Where is the ceramic material located in the injector. I'm no expert,but I did not see any ceramic material in the CR injector I disassembled. Not doubting your word. But if ceramic material is used I'd like to look at it.
    [​IMG]
  12. flyboy320
    flyboy320 New Member
    Nov 22, 2011
    4
    95 civic
  13. dsd
    dsd New Member
    Oct 21, 2012
    vw touareg tdi 2011
    New TDI HPFP victim
    I'm a recent victim of the TDI HPFP failure problem, which I was unaware of until I experienced it. I was driving my 2011 Touareg TDI to Lake Tahoe on I-80 when I experienced a complete loss of power and subsequent engine shutdown. A call to VW roadside assistance and a tow later, I was at a local dealership and was told that the fuel pump had "exploded," blowing debris through the lines and into the injectors. The dealership now has to await parts from VW (Germany, I assume) and plans to replace everything in the system up to and including the injectors. They also say fuel contamination was a possible cause, though they didn't know for sure.
    I would greatly appreciate responses to two questions:
    1) Does anyone know if VW is remedying this problem by using the same replacement parts that were installed at the time of manufacture, thereby creating the possibility (likelihood?) of a repeat problem "down the road?"
    2) Is there anything I can do to avoid this problem in the future by using fuel additives, etc.?
    P.S. I'm a mechanical dolt, so please give me a "dumbed down" explanation if you can.
    Many thanks in advance.
    DSD
  14. flyboy320
    Nov 22, 2011
    4
    95 civic
  15. chittychittybangbang
    23,900
    1. Nobody outside of Bosch-VW knows. Bosch has made a few revisions of their 2 liter fuel pump but they all have the same VW part number. I don't know about the 3 L fuel pump, not enough info.
    3. Fuel additives to add lubricity should help a lot. The best theories are that US fuel is low quality and inconsistent and the fuel pump just wasn't designed to withstand it. This wasn't a problem with older TDI engines. This is the best theory that I've heard.
  16. Plus 3 Golfer
    Plus 3 Golfer Member
    Aug 27, 2009
    87
    2009 Jetta TDI
    If you haven't done so, please file a complaint with NHTSA.
    Here's NHTSA defect investigation (search EA11003) into VW HPFP issues. Public data on the issue is limited to these current 66 document. VW has consistently said the cause is poor quality US fuel or misfuel. Fuel surveys support the poor quality of US retail fuel (in particular lubricity).
    One theory is that the HPFP roller can rotate on the cam which under the right conditions (for example, poor lubricity) can lead to catastrophic HPFP failure.
    Delphi has a new pump used on the VW Polo that eliminates this ability to rotate. Th quote below from the referenced Delphi link (bold emphasis added) is strong evidence that the Bosch HPFP has a design flaw:
  17. ksing44
    ksing44 Member
    Apr 11, 2010
    174
    2010 Golf TDI
    Southeast Pennsylvania
    Wow! That sounds terrific!!!
  18. rosaluma
    rosaluma New Member
    Oct 29, 2012
    9
    2012 Passat
    WTFuel?
    Just got word today that my 2012 Passat TDI with 5k miles has a fuel pump that disintegrated according to the service manager. I suspect the issues mentioned above.
    Didn't appreciated the accusatory tone the service dept. gave my wife as she turned in the vehicle. She was traumatized by the car failing in the middle of a busy boulevard, only to be questioned by the service manager about whether she (blond) put the appropriate fuel in the car. I thought service was in his title. :annoyed
    The car has had a fan running from time-to-time, after short in-town trips. The owner's manual indicated that this is normal. I am not so sure.
    Update: Just spoke to the service manager and he confirmed the part he is ordering is the HPFP. Have spent the past two hours combing this Forum amongst others and am very concerned. Many bad stories from 2010 about run around and finger pointing. After 20 yrs. of no issues with Toyota and Honda, we thought we'd jump on the VW bandwagon, with the TDI. We like the car, but are strapping in for a potentially bad ride.
  19. chudzikb
    chudzikb Member
    Feb 3, 2011
    434
    Lancaster PA
  20. darrelld
    darrelld Member
    Nov 4, 2010
    167
    2012 Passat SEL TDI, 2013 Ford C-Max SEL Hybrid
    ScanGaugeII, BlackVue Dashcam, V1 Radar Detector H
