common dieasel to CRDi
Discussion in 'General Diesel Discussion' started by brixspeed, May 24, 2009.
  1. brixspeed
    brixspeed New Member
    May 24, 2009
    1995 Land Rover Discovery (diesel)
    Looking for ways to convert it to CRDi
    Can anybody tell me if you can convert an ordinary diesel engine to a common rail direct injection? If there is a kit which you can remove the old direct injection to a new CRDi?
  2. Fluid
    Fluid New Member
    Jan 17, 2008
    482
    No way. The heads are completely different and the engine management would be impossible. In addition, since the timing belt or cams drive the injection pump you would have to somehow make your own timing belt or camshaft.
  3. chittychittybangbang
    23,889
    2nd. Without some way to manage the injectors it would be impossible. Maybe if you had a pumpe duse engine (so it wouldn't mess up the timing belt), had custom engine management, a custom common rail line, fuel pump, and injectors. By that point, you could probably buy a brand new car with the common rail engine.
  4. brixspeed
    May 24, 2009
    Thanks for the info guys.
