Coding Radio Jetta 2008 - 1K0 035 180L
Discussion in 'General Diesel Discussion' started by Gilbert.whittier, Jan 27, 2012.
  1. Gilbert.whittier
    Gilbert.whittier New Member
    Jan 27, 2012
    Jetta/2008
    After replacing battery my Ipod does not work. I tried several times to code radio (1K0 035 180L)from old code: 0010400 to 0010402 and still does not work. I am using VAG-COM . What am I doing wrong?
  2. Keithuk
    6,907
    Welcome to the forum Gilbert. welcometomyturbodies
    Well I don't know which year they started doing this but on newer VW's you don't need the radio code as the the ecu knows the original radio code. If you disconnect the battery for what ever reason and reconnect it checks the radio code and if it matches the original the radio will carry on working. If only if you change the radio to another vehicle you have to enter the radio code again.
    1K0 035 180L isn't the radio code its a part number which I don't have time to look up at the moment.
