Bypass oil filter
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by Pete, Mar 18, 2011.
  1. Pete
    Pete New Member
    Mar 14, 2011
    23
    2005 VW Jetta TDI
    Would you install a bypass oil filter system in your TDI? What are pros and cons?
  2. Keithuk
    7,073
    I'm not sure I know what you mean Pete, why would you want to bypass the oil filter system? Its bad enough having the long service intervals 20k without reducing the engine life even more.
  3. chittychittybangbang
    23,900
    Some people do this to add an even smaller micron oil filter. Here is an example: http://www.dieselgeek.com/servlet/Detail?no=462
    Pros: works.
    Cons: costs money that you won't really get back.
    If engines were having problems due to dirty oil I'd say it was an essential modification. While an advertised benefit is that the oil temperature will be more stable, it also takes longer to warm up the oil. Personally I'm not one of those people who worries about every little thing unless it will cause a big problem.
    Risk/benefit.
  4. Keithuk
    7,073
    Providing you change the oil regularly you shouldn't need extra filtering.
    I read many years ago (BBC's Tomorrows World) that they developed an oil filter that lasts the life of the engine it was something like a toilet roll. Then again they would sell many filters would they?
