broken belt tensioner
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by kmunroe, Dec 12, 2016.
  1. kmunroe
    kmunroe New Member
    Dec 10, 2016
    4
    2009 jetta tdi
    nova scotia
    anyone know about how many miles i can go with no serpentine belt.. it's a 2009 jetta tdi.. just running off the battery? i have to drive it about 35 miles to the repair shop .. i'm wondering if i can make it just on the battery
  2. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,681
    2012 TDI Tech Package 6mt
    Mile High
    You could, but overheating your car (no water pump) and that would cost more than a tow!
  3. kmunroe
    kmunroe New Member
    Dec 10, 2016
    4
    2009 jetta tdi
    nova scotia
    the water pump doesn't run off the belt on those ..
  4. xeno555
    Dec 12, 2011
    1,681
    Mile High
    Well without concerns of overheating, you can probably drive a few hundred miles on a well charged battery.
  5. kmunroe
    kmunroe New Member
    Dec 10, 2016
    4
    2009 jetta tdi
    nova scotia
  6. leocat66
    leocat66 Member
    Nov 5, 2016
    59
    V W, 2006 JETTA, TDI
    Slidell, Louisiana
    Did the tensioner just break or did is start making noise and if so what type of sound? Our '06 starts right up, runs normally for 30 seconds or so, then starts making a deep growling type, chuffing, breathing type noise similar to a worn bearing or bushing, but only at idle. It will stop the noise if the RPM is increased by only 50 or so revs and stays normal unless it is allowed to return to normal idle speed, at which time the noise returns. Once the engine temp reaches 150 or so the noise stops, and does not return unless the temp goes way down, say below 100, at which time it returns. Did you have these type noises before it gave up? When facing the engine the noise seems to be more to the right side near or below the tandem pump, and away from the tensioner, but noises can be difficult to trace. Tandem pump just replaced noise still there.
  7. kmunroe
    kmunroe New Member
    Dec 10, 2016
    4
    2009 jetta tdi
    nova scotia
    it broke... i pulled the pulley and part of the tensioner out with my fingers... and the spring and the rest of the tensioner remained bolted to the motor
