bora 2002 asz pd engine
Discussion in 'New TDI forum member introductions' started by brian69, Jul 5, 2012.
  1. brian69
    brian69 New Member
    Jul 5, 2012
    2002 bora tdi pd asz
    hi new on this was wondering if i could get some input just recently done timming belt and lifters and camshaft bearing but my bora is still rattly sounds as if lifters are not filling but plenty of oil on top end also white smoke and smell of unburnt fuel rattle gets worse when raved any help would b grate. would the camshaft cause these symtoms? :panic:
  2. Keithuk
    6,815
    Welcome to the forum Brian. welcometomyturbodies
    If you know the engine code ASZ all the info your after should be in FAQ if you search. ASZ isn't a common engine code.
