Bluetooth Install VCDS Help
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by Casacaiu, Jun 16, 2012.
  1. Casacaiu
    Casacaiu New Member
    Jun 16, 2012
    6
    Jetta TDI 2006
    Fog lights, blue tooth, vent visors, window tints
    Hello All,
    I have just recently installed myself the Bluetooth upgrade to my headunit. I purchased the VCDS to program in the 77 - Telephone option.
    However, I am missing some step, the systems is just not coming alive. I have the VW GPS MFD2 CD/DVD unit.
    I used the VCDS to program in some other Central Convenience options like windows up with remote, easy-in/out with the seats, unlock all doors with one remote click.
    I installed myself the fog kit, but that is a work in progress. I need to hook up one last wire to get it all to work.
    Anyway, if you have experience programing the VCDS with a vocal installation, please give me a shout or send me a message.
    23,767
    Which bluetooth? 9w3? full OEM retrofit job? Kufatec?
  3. D-Cell_Mekanick
    D-Cell_Mekanick Member
    Nov 6, 2010
    37
    VW Jetta TDI
    I believe he posted its a vocal which should be Volk-L. Same as I have.
  4. Casacaiu
    Casacaiu New Member
    Jun 16, 2012
    6
    Jetta TDI 2006
    Here is my part number. See picture. I am pretty sure it is the Volk-L.
    I did the installation myself. I wonder if I made a mistake. I am just not getting any response from it, it doesn't show up when I scan for bluetooth devices. I wonder if my telephone button in my steering wheel isn't connected to anything....I might have to take the center console apart again to get behind there to make sure everything is connected.
    On a side note, my fog light install is complete. I can scan the manual and post it here. I bought the fog light kit! It was pretty easy.
  5. Keithuk
    6,820
  6. D-Cell_Mekanick
    Nov 6, 2010
    37
    VW Jetta TDI
    It's been a while since I did my install. I remember haveing to remove a couple wires from the factory harness/plug and put them into a new plug. Did you do that? If so did you move the correct ones, I'd double check.
  7. Casacaiu
    Casacaiu New Member
    Jun 16, 2012
    6
    Jetta TDI 2006
    Hi, Sorry for the delay. Here is my current setup for my bluethooth. However, it is still not working. I will post all of the other options in the next reply so maybe somebody can steer me to the correct options and settings to make the system recognized.
  8. Casacaiu
    Casacaiu New Member
    Jun 16, 2012
    6
    Jetta TDI 2006
    Here are the options for all of the byte settings available for me. Anybody have any suggestions or can share with me the settings that work for them?
  9. Casacaiu
    Casacaiu New Member
    Jun 16, 2012
    6
    Jetta TDI 2006
    I did change out the wiring and followed the instructions. I already put the center console together. I want to make sure it is not a programming thing before I commit the time to taking everything apart....can you find out the setting that you have? Do you have a VCDS to go into those settings?
  10. D-Cell_Mekanick
    Nov 6, 2010
    37
    VW Jetta TDI
    What phone are you trying to pair with the Volk-L? I'll go check my coding now to see what mine is. I'll report back soon.
    Edit: my part number is as follows: 0--1K8 051 730 A--Telefon H01 5200
    Current coding: 402120
    Hope that helps
  11. Keithuk
    6,820
    D-Cell_Mekanick thats not a very clear picture. Once that screen is up and showing if you press Alt+Prt Sc that will copy just that screen to the clipboard. Open up Paint and press Ctrl+V to paste that picture in. You can drag the sides of the picture to resize it then save it as a jpg file and post that in here.
    You can add what ever picture you want too in your profile. Create a new album and upload the pictures into it then you just copy and paste the html code into a IMG and thread.
    e.g.
    [​IMG]
  12. D-Cell_Mekanick
    Nov 6, 2010
    37
    VW Jetta TDI
    I'm not very computer savvy. If I get time today I'll give it a try again.
  13. Casacaiu
    Casacaiu New Member
    Jun 16, 2012
    6
    Jetta TDI 2006
    Hi,
    Awesome help! I did get it to work. Once I have time, I will screen capture what is there to further aid the support base of the forum so when others have the same issue they will benefit from this thread.
    My telefon setting is different than D-Cell_Mekanick, it turns out the setting that worked was 412120 and not 402120.
    Also, in the CAN-Setting tab, the checkbox for Digital Radio needed to be UNCHECKED! I don't have a receiver for digital radio and it was blocking the Bluetooth from working.
    This was fundamental in catching why I was not getting anywhere. No change to the steering wheel buttons setting was necessary.
    Lastly, inside the Telefone 77 option, the testing option button was very useful to check if indeed the wiring was correct. Because, while the settings above were off/incorrect, the test did push a test dial tone through the speakers. Once, that occurred - my wiring was verified by the test dial tone, therefore; I started to try checkboxes in the CAN Setting Button.
    I will add pictures of the VCDS once I have time to do all that.
    ONE QUESTION STILL REMAINS:
    Does anybody with a Volk-L system get their music to play from the phone through the bluetooth to the car?
    The Volk-L recognizes my phone call and patches it through, but if I stream music on my phone, it won't go through the bluetooth. I am wondering if this is just my phone or a limitation of the Volk-L.
  14. lyusi_bg
    lyusi_bg New Member
    Nov 8, 2012
    2006 Passat, Jetta
    Hi I was having some issues my self that's how I got to your post. I read it all and I have just the same set up as yours, however if you have mfd2 navi you do have digital radio which is your Sat radio I have mine working but when play music will only play from top speakers and it would not me a good sound I am working on that as well I was wondering can you tell me where and how did you plug your volk wires on the back ? because the navi has more plugs and I remember when I was installing the Aux cable it had it was totally different from the other radios.
