biodiesel use in 2010 TDI Jetta
Discussion in 'Biodiesel general' started by scdvm, Feb 21, 2010.
  1. scdvm
    scdvm New Member
    Feb 21, 2010
    vw jetta tdi sportwagen
    Has anyone had any experience using biodiesel in the 2010 TDI Jettas? Do I need to do any modifications? Can I just change the oil more frequently?
  2. cvml98
    cvml98 New Member
    Mar 24, 2010
    Biodiesel use
    I just asked my local dealer about the use of biodiesel in VW TDI engines. He sent me a PDF file from VW with the following summary.
    In summary:
    1. Volkswagen recommends the use of standard
    diesel fuel or commercially supplied biodiesel
    blends of no more than five percent (“B5â€￾) biodiesel.
    2. Never use any fuel, whether diesel, B5 biodiesel, or
    otherwise, that fails to meet the latest petroleum
    industry specifications or that is not purchased
    from a commercial retail diesel pump. If you are
    unable to determine whether a particular fuel
    blend is B5 biodiesel that meets the latest biodiesel
    industry specifications, ask your service station for
    more information.
    3. Never use any fuel for which the contents cannot
    be identified.
  3. snorlax
    snorlax New Member
    Mar 3, 2010
    29
    I looked at a house last fall that had a couple of dozen big white plastic drums of biodiesel and used cooking oil stored next to the garage. The daughter had an A4 Jetta TDI and traded it on one of the first '10s. The new car was in the garage requiring a huge repair that was apparently not in the budget. The real estate agent didn't know the particulars, but it was enough proof for me that the pdf that CVML98 mentioned is the real deal.
  4. chef73
    chef73 New Member
    Dec 25, 2009
    12
    2010 jetta sportswagen TDI
    where to find b5
    I live in toledo ohio and i am wondering where to find a station that sells b5 boidiesel?
  5. TDI2000Zim
    TDI2000Zim Member
    Jul 23, 2010
    133
    2000 Beetle TDi...!@#$%...'14 Passat TDiSE
    None
    Fads come and go.
    But the fact that low sulfur diesel nowadays tends to breed algae, leads me to think that we are now feeding our cars and trucks Biodiesel, whethere intentional or not.
    Anyway, all diesel came from lving things in the first place.
  6. viellen
    viellen New Member
    Sep 5, 2010
    2010 Jetta Sportwagen TDI 6 Speed
    I just purchased my 2010 Jetta Sportwagen TDI this week. I did quite a bit of research on using biodiesel with it before purchase but since the post-injection DPF filters are so new (only out since 2009) there's not much "real-life" information out there. Basically, VW warranties the engine for ASTM-certified B5. When I contacted biodiesel wholesalers in my area they all encouraged me to use up to a B20 blend and I've found some sources online that seem to think that would be OK but it's a risk as the use of biodiesel with the DPF system can deplete oil, clog the filter and reduce efficiency. I've sourced commercial B5 in my area and intend to use that and have my oil and filter checked more frequently. I may use up to a B20 blend in the future but am taking baby steps right now since I really can't afford to replace the engine if it goes. Here are some links that might help you decide for yourself:
    Diesel particulate filter DPF and Adblue fluid FAQ
    Understanding the Post-Injection Problem
    VW world’s 1st automaker to warrant B5 biodiesel
    2009, 2010, and 2011 VW Jetta Sportwagen (Golf wagon) TDI buying checklist and FAQ (check out the Biodiesel section)
    Let me know if you find other info. I really want to use biodiesel but I don't want to risk recking brand new car. :/
    -Rebecca
  7. butch
    butch New Member
    Sep 20, 2010
    vw jetta tdi 2003
    I was using bio all most 100% no problems but I quit when they raised prices to match the big spike in price that one summer:rolleyes:
  8. Spoolin
    Spoolin New Member
    Sep 23, 2010
    14
    2011 Golf TDI
    Is there a site that has a list of all the B5 stations in the country? I'd be interested in throwing some in my new TDI. However I don't know of where any around me are.
  9. 3waygeek
    3waygeek New Member
    Oct 8, 2009
    74
    2010 Audi A3 TDI
    Try www.biodiesel.org -- it has a list of biodiesel retailers, but I have no idea how up-to-date it is.
  10. scdvm
    scdvm New Member
    Feb 21, 2010
    I was wondering if anyone with a post-2009 model has used 100% bio?
  11. dieseljohn
    dieseljohn New Member
    Nov 15, 2010
    27
    Jetta Wagon/2003
    11mm pump, air bags in rear, hitch
    Biodiesel use - after years of use...
    I've been using Biodiesel for several years in a variety of Diesels. Prior to this I blended filtered WVO, have even used used motor oil... I've also learned that filters can clog pretty quick... :)
    Problem you'll typically encounter with either is trouble with seals dissolving with both WVO and BioDiesel. Depending on how well your BioDiesel is processed will determine if you will have troubles that way. I've had to replace a few o-rings and the high pressure seals in my '91 300D. Other Diesels like a 1.6L Caddy I had to do nothing. GM 6.2 and 6.5 Diesels required replacing anything rubber in the system and an aux pump... ugly messes.
    THEN ON MY TDI... (which is sitting dead in my shop waiting for parts maybe because of the 1st tank of BioDiesel)
    on my 2003 Jetta TDI on the first full tank of BioDiesel I got error codes, hammering sound from my IP and loss of power... I pulled the injectors, two were bad... replaced the filter... cleared the code... a couple days later, hammering started, code P0252 reappeared. Talked to the Diesel shop, we determined a Diesel Purge might help it did... for about a day... then it started again... DP, one day... DP, 1/2 a mile... Got the triangle tool, pulled the pump apart, cleaned the Fuel Metering stuff... worked great for about 15 miles... then hammering in the IP, loss of power (not revs though) and P0252 and P0251 (ah ha! the metering code!)
    Here's picture of the insides for those of you that have no courage... or don't live life on the edge: (if you're faint of heart, don't look... if you like this sort of things will be happy to share the links to the inside of my Nikon D300)
    http://johnmeister.com/DIESELS/tdi/TDI-metering-control-ALH/ALL.html
    Bottom line, I can not say with certainty that this would have happened had I not had a full, 100% BioDiesel tank or not... But then again, this TDI will not see BioDiesel again... no point at 40-50mpg... will use it in my other Diesels.
    My 300D really lost power on that batch of BioDiesel so I suspect it was bad, I also had to change the filters on it. This was the first batch from a new co-op/friend... perhaps my last. ;)
    Anyway, watch for rubber parts dissolving, loss of power, lower fuel economy, but less costs (typically), nicer exhaust smell and the feeling like you're getting over on the system... i.e. no fuel taxes! We like to think it's free, but one spends a lot of time lugging cubies and buckets around, my shop floor is gross...
    Oh, BTW, that metering control part... it retails for about $1100 if you buy it from an injection shop, their cost is $500. The dealer doesn't sell it, only the pump, retail prices is $1402.
    I'm planning on buying a rebuilt pump from http://DieselVW.com unless one of you tells me I shouldn't. I think I'm going to spend the extra $100 for the full Bosch pump... the aftermarket part pump is $700 minus $300 core = $400.
    I've gone as far as I can with this without replacing the IP... Christmas break project...
    BioDiesel usually results in lower power and mileage... on my '91 300D in town mileage is typically 28-30mpg,
    with BD it can be as low as 23, typically 26 or so... and the car can be quite gutless. Smells better though.
    The exhaust on the TDI was much nicer with BioDiesel.
    I'm building an '83 J10 Stepside with a Scout Diesel drivetrain, ran an SD33 with 100% BioDiesel for over a year, NO PROBLEMS whatsoever... my '91 300D has been using it for years with mileage loss and power loss but no other issues... except for an o-ring in the fuel heater and the high pressure seals, which I can do in the car in very little time, again, faint of heart, don't look: http://johnmeister.com/DieselBenz/TECH/124-series/Pressure-Valve-Seal-Replacement-2010/ALL.html
  12. Audi5000TDI
    Audi5000TDI Member
    Dec 20, 2010
    109
    2013 touareg tdi
    CA
    ID-10T detector for VW Stealerships
    Does anyone ever read the Owners Manual? Try it some time, it works wonders... no one here warranties your car after giving you suggestions for misfueling over B5.
  13. goldstar
    goldstar New Member
    Feb 18, 2011
    20
    Polo 1.4 Tdi 2003
    I make bio for sale and my own use. I also make bio and store for a 2001 Golf owner that supplies his own feedstock. There have been no problems running 100% bio in close to 3 years. First thing he did was fit an after market fuel pre-filter (before the VW OEM filter) with a glass sight bowl using multi fuel hoses. Good quality fuel will not cause any problems in these cars.
    DieselJohn, I suspect poor fuel through poor conversion or unsuitable feed stock for the ambient temperatures you were experiencing.
  14. Cstdi
    Cstdi Member
    Mar 7, 2012
    61
    05Passat/10Touareg/11Golf
    OP read your manual please and follow it in regards to BD. Does your vehicle have a DPF? If so, don't use anything greater than B5. If you have a PD engine and no DPF, I would still be careful, monitor and limit the percentage of BD but personally in the, PD no DPF, I have strayed to the B50 mark during the summer with some performance issues and so backed it down some. If you do not have a PD (I don't know about the CR engine itself and BD) and also no DPF, but have vitron fuel line, do what you wish.
    The folks successfully running B100 here are in older TDIs
  15. Calidris96
    Calidris96 New Member
    Aug 5, 2010
    16
    2003 Jetta GLS TDI Wagon
    Montgomery, Texas
    Sigma-5 shifter, Panzer FMJ, Koni FSDs, towing springs, KermaTDI tune, Bosio DLC 1019, hula dancer
    I ran B100 almost exclusively in my 03 Jetta for about 75K miles with no problems at all. (Well, almost, it gelled on me once when a cold front sneaked up on me.) No noticeable decline in power or efficiency. Sounds like the guy with the trashed Audi, if it was caused by the fuel, was a home-brewer and could have screwed up a batch. I got mine from Houston Biodiesel. Their fuel came from the refineries in the Houston area. At the time there were several refineries producing biodiesel in the area. And it was generally about $0.50 less per gallon than petro-diesel, and still is.
