bad starting
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by mijan, Jan 19, 2011.
  1. mijan
    mijan New Member
    Jan 8, 2011
    4
    jetta tdi 2001
    hi i'm new in the forum i have a 2001 jetta tdi .i have problems when i start on my car and i don't know if is the battery or glows.please somebody help me.
  2. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,790
    Scotland
    PP764's, turbo and mapping
    Hi, welcometomyturbodies.
    What's the problem? Does the car turn over slow, not turn over, turn over fine but just not fire, start then conk out straight away?
    You'll need to give more info I think for people to help.:)
  3. chittychittybangbang
    23,882
    Location: FL. Probably not the glow plugs. They are not on before engine start when it's warm anyways. One way to eliminate them is to unplug the coolant temperature sensor. This tricks the ECU into maximum glow plug duration.
    It could be an air or fuel problem. You have to give more details like any error codes or other symptoms.
  4. Fluid
    Fluid New Member
    Jan 17, 2008
    482
    If it's the battery the engine will turn over slowly. If you take the car to Autozone or the like they'll test the battery and alternator for free.
  5. ocruz
    ocruz New Member
    Jan 19, 2011
    99 beetle
    need more info to try and help.. but battery is always a good place to start
  6. mijan
    mijan New Member
    Jan 8, 2011
    4
    jetta tdi 2001
    the car have a hard start like a sheep need move the key about 5 times when the car is cold thanks
  7. Seatman
    Jul 9, 2010
    5,790
    Scotland
    Lol I've never tried to start a sheep so I've no idea what you're saying. Sorry. But maybe someone else will.
  8. mijan
    mijan New Member
    Jan 8, 2011
    4
    jetta tdi 2001
    i can't star on my car in the first time i need to do 3 or 4 times i'm sorry don't speak very well english .so sorry for my wrong words
  9. Seatman
    Jul 9, 2010
    5,790
    Scotland
    No problem, I was just making a joke.:) Have you had a look through the faq at the top of the page? There's various things in there.
    Also do you think the engine turns over ok or do you think it turns over to slow and does it start fine when the engine is warm?
  10. mijan
    mijan New Member
    Jan 8, 2011
    4
    jetta tdi 2001
    when the car is cold,i try to start it up,but it wont crank,i have to try cuple of times to get it to crank.i think is a the hose the fuel filter to fuel pump.
  11. stroud2010
    stroud2010 Member
    Jun 12, 2009
    223
    '02 Jetta 1.9 TDI ALH and a wrecked(totaled) '98 NB 1.9 TDI ALH
    none.. yet..... ;)
    check the terminals for corrosion?
    When my battery terminals are corroded in my beetle, i'll turn the key and the dash will flash and relays sound like they're clicking all over the place. After cleaning the terminals, the car fires right up. my battery box is broken so the terminals see a lot of moisture and a lot of corrosion. ie white yellow build up on the battery posts.
