AUTO Unlock feature
Discussion in '2012-2016 VW Passat TDI forum' started by Texpar, Apr 11, 2012.
  1. Texpar
    Texpar New Member
    Oct 16, 2011
    15
    2012 Passat Opera Red TDI SEL
    Ok I took the car back to the dealer and they said that they could not duplicate the problem.....
    So when I walk up to the drivers door and put my fingers behind the handle to pull I hear the car unlock, BUT when I pull the handle the door does not open. after pulling 3 or 4 times it now will open (only heard the unlock once). I read the manual again and it states to make sure you are not touching the outside where the lock sensor is because it will not work. so I have been very conscious of this and still it often will not open. My Dad drove the car on a trip this last week and also experienced the same thing. My wife also has had this occur on her. Only seams to happen on the drivers door.
    So are we doing something to cause this? Are others having this happen to them?
  2. puttputtboom
    puttputtboom New Member
    Jan 9, 2012
    4
    1998 tdi
    No problems here, works perfectly!
  3. QuadricornSlayer
    QuadricornSlayer New Member
    Dec 18, 2011
    7
    2012 Passat TDI SEL
    I have had this happen several times as well...seems to occur when the car has been left out in the sun on a hot day. First time I had to open from the back door, then learned if I try several times it will eventually work. Probably just an alignment problem...going to have the dealer look at it tomorrow.
  4. QuadricornSlayer
    Dec 18, 2011
    7
    2012 Passat TDI SEL
    Dealer said they have heard of this problem and ordered a new door latch.
  5. Texpar
    Texpar New Member
    Oct 16, 2011
    15
    Thanks! mine is supposed to go in for a check up so I will mention it again to them.
