"ASR Off" light stays lit .. 2006 Jetta TDI
Discussion in 'Ross Tech VCDS forum' started by Concrescence, May 26, 2011.
  1. Concrescence
    Concrescence New Member
    May 25, 2011
    2006 VW Jetta TDI
    Hey everyone! New TDI owner here, and new member of myturbodiesel.com! Very stoked about getting good mileage!
    So here's my problem..
    "ASR Off" Light stays lit, indicating that I don't have stability control working. The vehicle with skid marks light also stays on in the instrument panel. Is this a common problem for the 2006 TDI's?
    The calipers and rotors were replaced right before I bought the vehicle (7000k ago), I thought it might be possible that the wiring to one of the wheel speed sensors wasn't connected properly and has just fallen off?
    Where are the speed sensors exactly?
    I have checked the fuses and when the rain lets up I'm going to check the wires going to the wheel speed sensors ...
    I'm waiting for my bentley manual to show up, hopefully it has info on how to test the actual sensors.
    Any help or insight would be greatly appriciated, I live in BC were there's lots of hills, rain and some times snow, so stability control does help on a regular basis for daily driving.
    Thanks a bunch guys,
    Trevor
    23,891
    It's also possible that the wheel sensors was damaged, problem since you took ownership?
    Also, get error codes so that you have a good idea what the problem is.
    Those lights would show up if you disconnected the battery but should go off.
  3. Concrescence
    May 25, 2011
    2006 VW Jetta TDI
    I actually baught the car in Ontario and drove across the country to BC and they it worked fine until I had been back for a few days...
    The trip took a bight out of my wallet so I'll have to wait to get the codes read.
    Also, how hard is the timing belt on these? I'm should do it as well now that the car is at 120k km's. I did the timing belt on my scirocco and it wasn't too bad.
    I read the instruction that are on this site, seems i need some special tools, where can I pick those up?
    Thanks
    Trevor
  4. chittychittybangbang
    23,891
    Timing belt is not too hard, the only hard part is supporting the engine to remove the motor mount. I rent the special tools but not to Canada, sorry. Shipping+duty is too much so it might be cheaper for you to buy them. There are some links in the writeup to sources.
  5. Concrescence
    May 25, 2011
    2006 VW Jetta TDI
    So I bought a VAGCOM system and ran the autoscan, this is what it came up with.
    Not too sure what the codes mean though...
    Friday,03,June,2011,19:08:55:36838
    VCDS Version: Release 10.6.3
    Data version: 20101206
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
    VIN: 3VWRT31K66M772845 Mileage: 120710km/75005miles
    00-Steering Angle Sensor -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: Malfunction 0010
    Address 01: Engine Labels: 038-906-016-BEW.lbl
    Part No SW: 03G 906 016 AB HW: 028 101 223 8
    Component: R4 1,9L EDC G000SG 7550
    Revision: --H01--- Serial number: VWZ7Z0F3302017
    Coding: 0050071
    Shop #: WSC 00066 000 00000
    VCID: 63CEB308DBD3
    1 Fault Found:
    005697 - Please check DTC Memory of A/C Controller
    P1641 - 000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 126
    Mileage: 113584 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 04:21:49
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.08 V
    Bin. Bits: 00001100
    Temperature: 33.3°C
    (no units): 16.0
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
    Part No: 1K0 907 379 P
    Component: ASR FRONT MK70 0105
    Coding: 0017025
    VCID: 3F865F7817FB
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1K0 820 047 DQ
    Component: Climatic PQ35 090 0505
    Shop #: WSC 00000 000 00000
    VCID: 76E8FA5C7841
    2 Faults Found:
    00229 - Refrigerant Pressure
    002 - Lower Limit Exceeded - Intermittent
    00819 - High Pressure Sensor (G65)
    009 - Open or Short to Ground
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
    Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
    Component: Bordnetz-SG H37 1002
    Revision: 00H37000 Serial number: 00000000261167
    Coding: 10018E234004180000140000001400000008730B5C
    Shop #: WSC 94788 999 54736
    VCID: 2A501E2CFC79
    Part No: 1K1 955 119 C
    Component: Wischer VW350 013 0402
    Coding: 00065493
    Shop #: WSC 94788
    4 Faults Found:
    00834 - Signal for Activation of Heated Rear Window
    009 - Open or Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00101001
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 63
    Mileage: 65363 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 14.55 V
    ON
    ON
    OFF
    OFF
    OFF
    01800 - Light Switch (E1)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 63
    Mileage: 120279 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.50 V
    OFF
    ON
    OFF
    OFF
    OFF
    00059 - Terminal 30 for Interior Lighting
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 63
    Mileage: 120279 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 12.50 V
    OFF
    OFF
    OFF
    OFF
    OFF
    00975 - Heated Rear Window (Z1)
    Freeze Frame:
    Fault Status: 00111100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 64
    Mileage: 65359 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 14.55 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
    Component: 3D AIRBAG VW8R 032 7900
    Revision: 03032000 Serial number: 0038FD0426AI
    Coding: 0013124
    VCID: 3972316009DF
    No fault code found.
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
    Component: J0527 034 0070
    Coding: 0000021
    VCID: 78F4F4647255
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1K0 920 852 P
    Component: KOMBIINSTRUMENT 3HL 4312
    Coding: 0023303
    Shop #: WSC 29252 067 57207
    VCID: 36683A5C38C1
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 F HW: 1K0 907 951
    Component: Gateway H10 0120
    Revision: H10 Serial number: 2800105C13910C
    Coding: 3D3F0B40071002
    VCID: 2A501E2CFC79
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Component: IMMO 3HL 4312
    VCID: 36683A5C38C1
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
    Part No: 1K0 959 701 K
    Component: Tuer-SG 024 2377
    Coding: 0001269
    VCID: 36683A5C38C1
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K1 909 144 K
    Component: EPS_ZFLS Kl.5 D06 1701
    VCID: 336E03482BB3
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 AF
    Component: KSG 0401
    Coding: 137803281B09058F880F048051A0
    Shop #: WSC 94788 999 91368
    VCID: 74ECC0546E3D
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
    Part No: 1K0 959 702 K
    Coding: 0001269
    VCID: 377637583FCB
    Address 56: Radio Labels: 1K0-035-161.lbl
    Part No SW: 1K0 035 161 A HW: 1K0 035 161 A
    Component: Radio DE2 012 0015
    Revision: 00012000 Serial number: VWZ4Z7F6132091
    Coding: 0010400
    VCID: 1D3AC5F0BD37
    1 Fault Found:
    01042 - Control Module; Not Coded
    000 - -
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
    Part No: 1K0 959 703 D
    Component: Tuer-SG 021 2434
    Coding: 0000144
    VCID: 31620940D1AF
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
    Part No: 1K0 959 704 D
    Coding: 0000144
    VCID: 3260064CD4A9
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D5A1530CD97
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    End ---------------------------------------------------------------------
  6. Stefan2006
    Stefan2006 New Member
    Sep 24, 2007
    226
    2006 VW Jetta TDI
    Those are intermittent electrical faults. Clear the codes and see what comes back, if it doesn't come back then I wouldn't worry about it. The ABS light is on because of this fault in the ABS module:
    1 Fault Found:
    Here is what the ross tech site says about it: http://wiki.ross-tech.com/wiki/index.php/01314
  7. Uwe@Ross-Tech
    Uwe@Ross-Tech New Member
    Sep 27, 2010
    20
    2009 Touareg TDI
    Yeah, but it's a pirated one. :bangshead
    -Uwe-
  8. Rig
    Rig Member
    Jul 19, 2011
    55
    2006 Jetta TDI, 1998 Jetta TDI
    Southeast Alaska
    Remove a front wheel, and you'll see the actual wheel sensors and their wiring harnesses. I broke the wires on mine from using cable chains to get unstuck last winter. The clearance between the tire and the wires is not very much. The wires are easy to see, if they are compromised in some way, or just unplugged.
    I installed in a new wiring harness for mine, because the wires were snapped off too short to splice. Otherwise, it would have been a simple thing to splice the wires and protect it with heat shrink.
    My sensors were fine.
