Any good mechanic for tdi Stratford Ilford?
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by Valentinkp, Jan 7, 2018.
  1. Valentinkp
    Valentinkp New Member
    Jan 7, 2018
    'vw golf mk4 1.9 2002 ASZ
    London Forest Gate
    Hi!
    I recently changed the oil. On an ASZ 1.9 turbo.
    After this engine start to loose power more and more, and to produce lot of black smoke.
    After 5 miles, barely can start to run in first gear, I thought it might be a conector or a pipe out, but I checked and looks ok to me. Also I thought it was overfilled but in the oil tub remained 0,5L which means they only filled with 4,5 L which is ok.
    I might need to replace the turbo, so I need a recommendation....
    Thank you!
  2. Keithuk
    7,235
  3. Valentinkp
    Jan 7, 2018
    London Forest Gate
    You suggest my message should have been posted in different category?
  4. Keithuk
    7,235
    I haven't suggested your message should be in another category. I'm saying: First posts normally go in introductions else you could get a free fix and we never see you again!!!
    Can't you read what I've said?
  5. Valentinkp
    Jan 7, 2018
    London Forest Gate
    I can read, I can not understand. For example, what is "introductions" in your opinion?
  6. Keithuk
    7,235
