Alternator clutch / tensioner noise
Discussion in 'General Diesel Discussion' started by Johnno, Mar 30, 2012.
  1. Johnno
    Johnno New Member
    Mar 21, 2012
    16
    Vw Golf 2002
    Hey guys, yet another question.
    My tensioner on my aux belt is jumping around like mad on idle, a slight rev and it goes. It feels pretty weak when I put a 16mm spanner on the release.
    Read here about the alternator clutch, so I removed belt and put a screw driver between the fans in unit, but the pulley won't go either way, it's
    Locked with the fans.
    Usually I would think this was ok, but can anyone shed some light on this? I think the tensioner is at fault being too weak. But I never know with this German engineering lol.
    Johnno
  2. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,096
    Jetta 2003, Golf 2001
    The alternator pulley on all A4-and-later TDIs is supposed to be a one-way (so-called "clutched") unit that turns the alternator when turned clockwise, and lets the alternator "slip" ahead when turned counter-clockwise... Yours sounds like a classic case of one that has locked up... yes, it will cause the tensioner to bounce around like crazy... (you need special splined tools to remove the pulley from the alternator shaft...)
    All the best,
    Yuri
  3. Johnno
    Johnno New Member
    Mar 21, 2012
    16
    Vw Golf 2002
    Won't a hammer do?
    It's a golf does it run the same system? Hate these cars!
  4. Ol'Rattler
    Ol'Rattler Well-Known Member
    Apr 24, 2011
    783
    06 TDI Jetta
    Marysvile, WA.
    About as well as using a hammer to remove the radio. If you have a big enough hammer and swing it long enough and hard enough, you can remove anything with it.
    The tool Is 2 pieces. one part holds the alternator shaft while the other part spins the center part of the pulley off of the alternator shaft.
  5. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,792
    Scotland
    PP764's, turbo and mapping
    Just send your golf up to me bud, I like them very much :D
  6. Johnno
    Johnno New Member
    Mar 21, 2012
    16
    Vw Golf 2002
    I have been a technician on trucks all my life and I've never come across so much bollocs on one car.
    A sledge will do. Through the roof.
    Anyway is there a aftermarket fitting with no clutch in?
  7. Ol'Rattler
    Apr 24, 2011
    783
    06 TDI Jetta
    Marysvile, WA.
    You could use a gasser pulley. But then you would be right back were you are now because your pulley is acting exactly like a solid gasser pulley does. The belt would still be jumping around at idle, and over time destroying the tensioner.
    The clutched pulley is there for an extremely valid reason on TDI's.
