.658 5th gear install
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by Audi5jim, May 4, 2008.
  1. Audi5jim
    Audi5jim New Member
    Jan 26, 2008
    49
    2003 VW Golf GL 2 door TDI/5-speed
    none
    //Audijim’s .658 5th gear installation procedure on a Mk IV Golf TDI (ALH)/ 02J (EGR) 5 speed:
    Parts needed:
    02Z 311 158 A (Large Gear)
    02Z 311 361 A (Small Gear)
    02A 311 324 C Concave Spring Washer for small gear
    02A 301 215 A Gearbox Cover Gasket
    2.0 liters (+/-) VW G50 (or alternate brand) full synthetic gear oil 75W/90
    Tooling:
    Metric Tool set
    11 mm socket for gearbox Cover bolts
    17 mm socket to remove wheel lug bolts
    17 mm Allen socket for drain/fill plugs
    8 mm Triple Square for the Selector Fork mounting bolts
    T60 Torx socket for the bolts that hold on 5th gears
    T25 bit to remove the screw for the inner fender liner
    Electric heat gun or propane/MAPP gas torch (as needed)
    Gear Puller, 3 arms
    Torque wrench in ft/lbs.
    Oil Catch
    Impact gun (if you have air tools available)
    Procedure:
    -Inventory your parts.
    -Inventory your tool list.
    -Review Maintenance Manual Procedure(s).
    -Position vehicle for maintenance.
    -Place Wheel Chocks behind rear wheels.
    -Jack up the front of the vehicle. (Refer to Owner’s Manual or Maintenance Manual for proper Jack Points)
    -Place vehicle on jack stands. (Refer to Owner’s Manual or Maintenance Manual for proper placement)
    -Remove Front Left (driver side) wheel with 17 mm socket.
    -Remove Inner Fender Liner with T25 Torx bit.
    -Clean the area around the Fill and Drain plugs to prevent internal contamination.
    -Loosen and Remove Fill Plug. Clean Fill Plug.
    -Loosen Drain Plug.
    -Position Oil Catch under the Drain Plug.
    -Continue with the removal of the Drain Plug. Clean Drain Plug.
    -Remove the 5 Bolts that hold on the Gearbox Cover with the 11 mm socket. Loosen the top bolts first in the event that all the gear oil has not drained out of the Drain Plug hole. There will be residual gear oil behind the gearbox cover.
    -Remove the Gear Selector Bolts with the 8 mm Triple Square socket.
    -Remove the Gear Selector Pins and Gear Selector Lever.
    -Remove both Torx bolts with the T60 Torx socket. You may need to have a second person help you by applying the brakes to hold the transmission from turning. These were easily removed with an impact gun.
    -Note how the OLD GEARS are oriented on the shafts. The NEW GEARS will be installed the same way. Pay attention to how flush the gears are to the ends of the shaft.
    -The Synchronizing Hub has Spring Circlips on the Outside (facing you) and Backside of the gear. The Circlips hold the 3 Locks in place.
    -Remove the Spring Circlip and slide the Locking Collar BACK.
    -Reinstall the T60 Torx bolt finger tight.
    -Install the Gear Puller arms into the 3 slots that do not have the Locks. The gear puller arms need to fit behind the synchronizing hub.
    -Apply heat to the Synchronizing hub and/or Aerokroil/PB Blaster, ect to the splined shaft area.
    -Remove Remove Synchronizing Hub with Locking Collar.
    -Note the position of the 3 Locks that are being held in with the Spring Circlip on the back side of the synchronizing hub.
    -Remove the Synchronizing Ring. This may have come off with the Synchronizing Hub and Locking Collar or it may still be on the Large 5th Gear.
    -Remove Large 5th gear. It rests on Needle Bearing set in a plastic cage.
    -Remove the Small 5th gear. It is on a splined shaft. A little wiggling of the gear will allow it to slide off.
    - Clean the Synchronizing Hub and Locking Collar, Needle Bearings, Spring Circlips, Locks, Synchronizing Ring, Selector Lever and Pins, and the Gearbox Cover.
    -Clean the transmission case.
    -Heat the new Small 5th gear with Electric Heat Gun or Propane/MAPP gas torch.
    -Install new Small 5th gear (02Z 311 361 A) on Splined Shaft.
    -Lubricate the Needle Bearings with VW G50 (or alternate brand) full synthetic gear oil 75W/90
    -Install Needle Bearings on shaft.
    -Install new Large 5th gear (02Z 311 158 A)
    -Install Synchronizer Ring on the Large 5th gear.
    -Assemble the Synchronizer Hub/Locking Collar/Locks and Spring Circlips. Note the 3 grooved teeth on the Locking Collar. The Locks fit at these positions between the Narrow Grooves on the Synchronizer Hub and the Locking Collar. Note the orientation of the Locks were they were removed and Install the same way. Install the Spring Circlips.
    -Heat the hub of the Synchronizer Assembly with an Electric Heat Gun or Propane/MAPP gas torch.
    -Install Synchronizer Assembly on the Splined Shaft. Be careful not to damage the Synchronizer Ring that sits on the Large 5th gear, it may have slipped off the Large 5th gear. Make sure it is resting flush against the Large 5th gear.
    -Install the Small Concave Spring Washer (02A 311 324 C) with the T60 Torx bolt on the Small 5th gear.
    -Note the orientation of the Concave Spring Washers. The cone should be against the bolt, the outer edge of the Concave Spring Washer should be against the Small 5th gear.
    -Install the Concave Spring Washer that was removed earlier with the T60 Torx bolt onto the Large 5th gear shaft.
    -Note the orientation of the Concave Spring Washers. The cone should be against the bolt, the outer edge of the Concave Spring Washer should be against the Synchronizer hub.
    -Torque T60 Torx bolts to 59 ft/lbs (80 Nm). You may need the assistance of a second person to apply brake pressure while you torque these bolts.
    -Install the Selector Lever and Pins with the 8mm Triple Square bolts.
    -Torque the 8 mm Triple Square bolts to 18 ft/lbs (25 Nm)
    - Install the Gearbox Cover with new gearbox Cover Gasket (02A 301 215 A) with 5 11mm bolts.
    -Torque the Gearbox Cover bolts to 9 ft/lbs.
    -Install Drain Plug with 17mm Allen socket.
    -Torque 17mm Drain Plug to 20-25 ft/lbs.
    -Service Transmission with 2.0 liters (+/-) or until full of VW G50 (or alternate brand) full synthetic gear oil 75W/90. Make sure vehicle is Level when Servicing Transmission. Fill gear oil to the Lower Edge of the Filler Plug Hole.
    -Install Fill Plug with 17mm Allen Socket.
    -Torque 17mm Fill Plug to 20-25 ft/lbs.
    -Install Inner Fender Liner with T25 Torx screws.
    -Install Front Left (Driver Side) wheel.
    -Torque Wheel Lug Bolts to 95 ft/lbs.
    -Start vehicle and check for leaks.
    -Test drive vehicle, check for leaks again.
    -Enjoy the added fuel mileage by dropping your RPMs at highway speeds!
  2. Blackcat
    Blackcat New Member
    Jul 31, 2007
    137
    Did you need any other modfication? The existing writeup that I saw mentioned that you need some mod to the "spring plate". It says that tdiparts includes it but I don't know what it is.
  3. Audi5jim
    Audi5jim New Member
    Jan 26, 2008
    49
    none
    What they call the "Spring Plate" is actually called (and what I called in my procedure) a "Concave Spring Washer". If you didn't buy your .658 5th gear as a kit, you would have to modify the concave spring washer for the smaller 5th gear. The modification is just making the diameter smaller by a couple millimeters. I will measure the difference and update my procedure. I also found the P/N in ETKA for the correct smaller diameter concave spring washer and supplied it in my parts list.
    Was my procedure helpful? Good/bad/ugly? :) I appreciate the feed back.
  4. chittychittybangbang
    23,891
    The concave spring washer is also called a belleville lockwasher. TDIparts includes it with their kit.
    Good writeup, but pics are always helpful! I will edit the how to list in the forum. Trans fluid capacity is 2.1L.
  5. Audi5jim
    Audi5jim New Member
    Jan 26, 2008
    49
    none
  6. chittychittybangbang
    23,891
    Excellent pics. The site needs a pictoral and writeup on mk4 jetta/golf transmission removal and installation, if you want to do that, it would be helpful to the site and to other people.
  7. Audi5jim
    Audi5jim New Member
    Jan 26, 2008
    49
    none
    Unfortunately, I removed the trans on Saturday and didn’t document a thing. Perhaps when I reinstall it, I could document that (time permitting)
  8. MAXRPM
    MAXRPM New Member
    Sep 10, 2007
    147
    I have done 4 different gear swaps in TDI's, and I still do not understand why everybody is taking apart the syncro and clips on these gear swaps, I have been able to hook up the big gear and syncro together with the puller and pull the whole thing (syncro and all) when I put it back I go ahead and put everything as one solid unit, it is way way easier than having to assemble the synchro and clips, it will save you at least 30-45 minutes this way, total time on this Job is about 45 min.
  9. chittychittybangbang
    23,891
    Yeah, it would be easier but my puller can't fit for removal. Yes, when you put it back it should be assembled.
  10. bigshow
    bigshow New Member
    Feb 14, 2008
    107
    It look like it'd be hard to remove the gear with the syncro on since it's blocking the gear.
  11. MAXRPM
    MAXRPM New Member
    Sep 10, 2007
    147
    I have a puller that is able to grab the gear from the back and when I pull it out, I am able to pull the gear and syncro together, no messing around with taking the syncro apart, I have done 4 gear swap so far this way, no problem quick and easy.
  12. rkovacs
    rkovacs New Member
    Mar 11, 2012
    5
    2005 VW Jetta TDI Wagon
    I put the gear back on before I put the selector gear and 3 teeth on, but now I can't figure out how they all go on. Does this have to be done before I press the gear back on? Also I ended up breaking two of the locking teeth. Can I order these from the VW dealer?
