2013 Golf Wagon Fuse Panel
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by Dave Nicholls, Apr 16, 2013.
  1. Dave Nicholls
    Dave Nicholls New Member
    Apr 8, 2013
    19
    2013 VW Station Wagon TDI, Select Shift Transmission
    Teulon, Manitoba Canada
    none
    There is a fuse panel in the engine compartment, but the manual says ther is one under the dash in the car is well. I cannot find a way to remove the panel in the dash.
    - is there a pannel in the dash
    - where can I get a drawing of what fuses are for what. The manual does not tell you this ?
  2. DubFamily
    DubFamily Active Member
    May 30, 2012
    901
    2014 BMW 328D xDrive
    Southern Maryland / DC
    Unfortunately, VW is really horrible about fuse panel schematics; they are nearly impossible to find with any sort of reliability. you should be able to go to your dealer parts department and ask for one for your VIN.
    As far as where the dash fuse panel is: Open the driver's door and look at the side of the dashboard that butts up against the closed door, the panel is right there. Along the lower portion of the long "front" edge of the panel is a small cut out to allow you to pull the cover off.
    This image shows the location at least:
    [​IMG]
  3. CDN TDI
    CDN TDI New Member
    Mar 29, 2013
    19
    2011 TDI Jetta 6MT
    What's your Vehicle Sales Type? It'll be on the PR Label for your vehicle in your Service/Warranty Book and/or stuck to the spare tire well. It'll be something like 162W9L. See image below under "Type". I will post a Fuse Overview if you provide the Sales Type.
    [​IMG]
  4. Dave Nicholls
    Apr 8, 2013
    19
    none
    PR Label as Requested.
    Here is a copy of my PR Label as requested and thanks for getting this information.
  5. CDN TDI
    CDN TDI New Member
    Mar 29, 2013
    19
    2011 TDI Jetta 6MT
    Here you go. This is specific to your vehicle: AJ539M Golf Variant Jetta SportWagen.
  6. DubFamily
    May 30, 2012
    901
  7. Dave Nicholls
    Apr 8, 2013
    19
    none
    Fuse Box
    Thanks for the info...
  8. Dave Nicholls
    Apr 8, 2013
    19
    none
    Thanks for the data. Any chance you can the diagrams for the two fuse boxes to go with the excellent data listings?
    Thanks
  9. CDN TDI
    CDN TDI New Member
    Mar 29, 2013
    19
    2011 TDI Jetta 6MT
    Not sure exactly sure what you're asking. You're missing an important verb in your question. I tried producing another document for you, but VW doesn't allow ELSA documents to be saved, so I have to print to PDF. This process clips all of the images in the conversion. I can post the images individually for you, if that's what you're asking.
  10. Dave Nicholls
    Apr 8, 2013
    19
    none
    Yes that is what I need. I only got a couple of partial images. What I'm looking for is an image showing where each of the numberd fuse is. The listing is great but I don't know here (for example) #6 fuse is.
    Thanks and sorry I'm such a pain.
  11. CDN TDI
    CDN TDI New Member
    Mar 29, 2013
    19
    2011 TDI Jetta 6MT
    Here you go!
    Sudhir Saxena likes this.
  12. Dave Nicholls
    Apr 8, 2013
    19
    none
  13. Pest
    Pest New Member
    Dec 4, 2016
    2013 VW Jetta TDI
    Bow, NH
    How does the layout for the AJ539L differ if at all and if it does I could use that one if someone has access to it. Thanks.
  14. Keithuk
    6,910
    Not much as the AJ539L has a LHD NFP - 6 Speed the AJ539M has a LQV LTE MFL MSV NJK NLP PBF - 6 speed DSG.
  15. Pest
    Pest New Member
    Dec 4, 2016
    2013 VW Jetta TDI
    Bow, NH
    Thanks. Once I started looking through the documentation that had been posted closely I was able to differentiate based on what options the car has that the basic configuration is consistent. The car is all fixed.
