2011 VW TDI Jetta (manual), Transmission Fluid Dipstick?
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by Jason Moscatello, Nov 7, 2016.
  1. Jason Moscatello
    Jason Moscatello New Member
    Nov 7, 2016
    7
    Volkswagen, Jetta, 2011
    New England
    This is a very basic question but the owner's manual that comes with the car is rather rudimentary. We'd like to check the level of the transmission fluid and would like to know if there is a dipstick (and where) or if the level can only be checked by draining. Thank you in advance.
  2. Vwman2015
    Vwman2015 Member
    Oct 3, 2015
    302
    Vw golf, mk5 2005 sdi, bkd engine
    Clacton
    No dipstick on a manual only an auto, you need to jack the car up on stands, two on front and two on rear on a level stable ground.
    Then undo the filler bolt plug, the oil should sit just below the bottom of the oil plug bolt hole, that's the max line.
    Why do you suspect the fluid is low?
  3. Jason Moscatello
    Nov 7, 2016
    7
    New England
    Thank you for the information. There is a high-pitched whirring in the higher gears when she is under load.
  4. DubFamily
    DubFamily Active Member
    May 30, 2012
    911
    2014 BMW 328D xDrive
    Southern Maryland / DC
    Are you certain it's from the transmission, and not the turbo or the intake?
  5. Jason Moscatello
    Nov 7, 2016
    7
    New England
    Not certain at all, we are attempting to triage. Not our first manual diesel (still have an '86), but this is our first turbo. Turbo was on the list of potential issues but not much experience with them.
  6. Jason Moscatello
    Nov 7, 2016
    7
    New England
    Well, she got stuck in gear and was unable to shift. Car is now in the shop; probably transmission after all.
    Vwman2015 likes this.
  7. DubFamily
    May 30, 2012
    911
    Ouch, good luck with it
  8. Jason Moscatello
    Nov 7, 2016
    7
    New England
    Appreciated!
  9. jason_
    jason_ New Member
    Sep 22, 2014
    10
    09 CR tdi wagon
    Usa
    I'm curious of results?
    Sent from my S-Off'ed HTC One...
  10. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,684
    2012 TDI Tech Package 6mt
    Mile High
    No dipstick, inverted fill.
    Probably the valve body and clutches.
  11. jason_
    jason_ New Member
    Sep 22, 2014
    10
    09 CR tdi wagon
    Usa
    ? Thought it was a manual? At the least something without a valve body?
    I can't see signature with Tapatalk, maybe I'm missing something?
  12. Jason Moscatello
    Nov 7, 2016
    7
    New England
    Sorry for the delay, folks; holiday and all.
    For the transmission suddenly getting stuck with no warning, somehow the output shaft seized internally on the transmission which "Caused clutch pressure plate to explode. Metal cut gearbox and drained gear oil. Flywheel is burned heavily from friction."
  13. jason_
    jason_ New Member
    Sep 22, 2014
    10
    09 CR tdi wagon
    Usa
    Low on fluid?
    My dad would call hot spots on bearings "grease burns"... Hehe
  14. Jason Moscatello
    Nov 7, 2016
    7
    New England
    Not low on fluid until it damaged itself somehow.
