2010 Golf TDi throwing code P0472
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by Disturbancetkxe, Feb 15, 2012.
  1. Disturbancetkxe
    Disturbancetkxe New Member
    Feb 15, 2012
    8
    2010 Golf tdi 6mt
    Good afternoon, I have been on the site for awhile just never created an account.
    I have been dealing with the check engine light on my Golf for awhile now. There hasn't been any symptoms or issues that would make me not drive the vehicle.
    As i looked up the generic code reader code, I found a tiguan tdi in europe with the same issue but appearantly not the same fix.
    Has any body ran into
    P0472 - Exhaust back pressure sensor circuit low input.
    Or
    P0471- Exhaust pressure Sensor 1 (g450): Implausible Signal.
    Thanks for any help
    23,767
    Haven't seen this prob before but the exhaust back pressure sensor is to operate the emissions. implausible signal usually means sensor is bad or has faulty wiring. This is a warranty job as well as long as you're not over the mileage.
  3. Keithuk
    6,819
    VAG Error Code: 16855
    EOBD II Error Code: P0471
    Fault Location:
    Exhaust Gas Pressure Sensor 1 (G450) - Implausible Signal/Range/Performance Problem
    Possible Cause:
    Wiring/Connector(s).
    Hose from/to Exhaust Pressure Sensor 1 (G450) faulty.
    Exhaust Pressure Sensor 1 (G450) faulty/incompatible.
    Possible Solutions:
    Check Hose from/to Exhaust Pressure Sensor 1 (G450).
    Check/Replace Exhaust Pressure Sensor 1 (G450).
    Check Exhaust Pressure Sensor 1 (G450) Compatibility.
    The new Exhaust Pressure Sensor must be calibrated with VAG-COM\VCDS.
    Special Notes:
    This Fault Code often indicates an incorrect/incompatible Exhaust Pressure Sensor 1 (G450) being installed. VAG uses two different types of sensors, 076-906-051-A (formerly 03G-906-051-A) for Engines through MY 2009 and 076-906-051-B for Engines from MY 2010. If in doubt check the Part Number of the Exhaust Pressure Sensor 1 (G450) and compare it against the Parts Catalog.
    Tech Notes:
    Replacing the exhaust back pressure usually takes care of the problem.
    When is the code detected?:
    An Exhaust Back Pressure (EBP) signal that is detected out of range (high or low) by the Engine Control Module (ECM) will cause the engine to ignore the Exhaust Back Pressure (EBP) signal and disable exhaust back pressure operation.
    Description:
    The Exhaust Back Pressure (EBP) sensor is a variable capacitance sensor that, when supplied with a 5-volt reference signal from the Engine Control Module (ECM), produces a linear analog voltage signal that indicates pressure.
    The Exhaust Back Pressure (EBP sensor's primary function is to measure exhaust back pressure so that the Engine Control Module (ECM) can control the Exhaust Back Pressure Regulator (EPR) when needed.
    VAG Error Code: 16856
    EOBD II Error Code: P0472
    Fault Location:
    Exhaust Gas Pressure Sensor 1 (G450) - Low Input/Short Circuit to Earth
    Possible Cause:
    Fuse(s).
    Wiring/Connector(s) short to earth.
    Exhaust gas pressure sensor (G450).
    Engine Control Module (ECM).
    Tech Notes:
    Description:
    The Exhaust Back Pressure (EBP) sensor is a variable capacitance sensor that, when supplied with a 5-volt reference signal from the Engine Control Module (ECM), produces a linear analogue voltage signal that indicates pressure.
    The Exhaust Back Pressure (EBP) sensor's primary function is to measure exhaust back pressure so that the Engine Control Module (ECM) can control the Exhaust Back Pressure Regulator (EPR) when needed.
  4. Disturbancetkxe
    Feb 15, 2012
    8
    2010 Golf tdi 6mt
    Yeah I have 60k on the vehicle already, does any one have a vw part number for the sensor, I have searched 1stvwparts database and I only can get a description not a part number or a view od what sensor it could be.
  5. Keithuk
    6,819
  6. Disturbancetkxe
    Feb 15, 2012
    8
    2010 Golf tdi 6mt
    Is there a difference between 076906051a and 076906051b? Can I adapt the new sensor with out vagcom?
  7. Disturbancetkxe
    Feb 15, 2012
    8
    2010 Golf tdi 6mt
    Thanks for the help also, i really don't want to give the dealer a few hundred for a 80 dollar part.
  8. Keithuk
    6,819
    Sorry I've just noticed its a 2010 Golf. Can't you get this replaced under warranty or has your mileage exceeded the upper limit?
  9. Disturbancetkxe
    Feb 15, 2012
    8
    2010 Golf tdi 6mt
    I have hit 60k and the dealer is quick to respond to everything that isn't covered under the 6yr 100,000 mile warranty.
    Supposably sensors are not covered.
  10. Keithuk
    6,819
    I assume you mean a 6yr 100,000 mile extended warranty plan?
    We've talked about warranties on here before it appears in the US its 3 years or 36k. In the UK its 3 years or 60k so if you were over here then your just on the edge at 60k.
  11. Disturbancetkxe
    Feb 15, 2012
    8
    2010 Golf tdi 6mt
    Sorry yes extended warranty, currently work is blocking every website with information on the topics.
    Sadly I am in the states, I wish I was in the UK, or else where.
  12. Disturbancetkxe
    Feb 15, 2012
    8
    2010 Golf tdi 6mt
    Purchased a second sensor this time 076906051b instead of 076906051a, light still persisted so dropped it off at the dealers, a friendly tech looked at it all day, they are keeping it for a second night hopefully i can get my baby back and enjoy the weekend with out a check engine light.
    I will post up the fix once completed since its not the usual sensor issue.
  13. Disturbancetkxe
    Feb 15, 2012
    8
    2010 Golf tdi 6mt
    Finally got my car back, Still researching what the dealer had replaced.
    Car was showing p0472 -G450 sensor low voltage after a replacing this sensor on the left hand side of the motor and no results. Dealer tested wiring and ecu so on so fourth.
    By day 7 dealer installed G505 sensor, which is the exact same part number as g450. I was told the sensor sits behind the head. I have yet to look for it or research this, The one VW illustration that I have only shows one Differential Pressure Sensor on the CJAA motor. If any one has a more detailed Illustrations, I would love to see them.
    I posted this information just in case some one else runs into a similar issue.
  14. chittychittybangbang
    23,767
    Check out the DPF FAQ article, there may be some pics in there.
  15. ilyago
    ilyago New Member
    Mar 9, 2011
    5
    VW JSW 2010 Manual
    So the fix was the G505 sensor? I assume the CEL stayed off after that.
    I have a 2010 JSW MT with 75000 miles. Just got the P0472 code this weekend,
    so I am researching the issue. Yours is the only post I found on the TDI sites with code P0472 and CJAA/CBEA motor. I am not getting any other codes, just this one.
    How expensive (parts, labor) was the fix?
