2009 Jetta Wagon CEL P2563 where is the Boost Control Position Sensor located?
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by Greg Peters, Jul 8, 2011.
  1. Greg Peters
    Greg Peters New Member
    Jul 8, 2011
    2009 TDI
    2009 Jetta TDI with CEL P2563 TC Boost Control Position Sensor
    I have have been searching for this code and not finding much.
    I have saw code P2564 code which looks like it could be a bad wire issue.
    Going to try to get under the car tonight.
    1 Fault Found:
    009571 - Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
    P2563 - 000 - - - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 77
    Mileage: 113172 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 12:33:54
  2. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,792
    Scotland
    PP764's, turbo and mapping
    I think that may be on the turbo or the actuator for the turbo with 3 wires going to it, I'm not 100% sure on that but that's what was on the earlier jetta PD's, quite often one of the wires would become damaged and throw a code because the various parameters aren't adding up to the ecu's wish. I also found this little bit of info that might be of interest.:)
    http://ww2.justanswer.com/uploads/asemaster327/2008-07-22_005829_ANSWER.pdf
    There's maybe more in the faq too.
    welcometomyturbodies
  3. chittychittybangbang
    23,889
    I believe it's the black thing on the end of the VNT actuator.
  4. Greg Peters
    Jul 8, 2011
    2009 TDI
    I found the location.
    It seems like earlier cars it was under the engine - that is where I was looking.
    Mine is on top of the engine in the back - easy to get to.
    I checked the wires and plug, it all looks good.
    I guess I need to check resistance on it now?
  5. chris.howard713
    chris.howard713 New Member
    Oct 24, 2011
    2009 VW Jetta TDI
    having similar issues...
    I am getting the P2563 CEL Code too and also am receiving a "Engine Fault Workshop" on my display and the glow plug light is blinking. Some times I notice a difference in performance and other times there is no difference. Has anyone found out what is causing this? Also does anyone have a wire schematic for this? I have located the sensor. I am going to go over the PDF that was put out a little earlier in the thread on the issue to see if it helps me figure anything out. Just wanted to see if anyone else has gotten anywhere with it.
  6. Keithuk
    6,908
    Welcome to the forum guys. welcometomyturbodies
    google it for this
    EOBD II Error Code: P2563
    Fault Location:
    Turbocharger (TC) boost control position sensor - range/performance
    Possible Cause:
    Wiring.
    Turbocharger (TC) boost control position sensor.
    EOBD II Error Code: P2564
    Fault Location:
    Turbocharger (TC) boost control position sensor - circuit low
    Possible Cause:
    Wiring short to earth.
    Car: 2009 TDI
    Please add Jetta to your car spec Greg?
