2006 Jetta TDI with BRM engine- broke timing belt - swaps?
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by dbandel, Sep 29, 2017.
  1. dbandel
    dbandel New Member
    Dec 3, 2010
    27
    Maryland
    Is the BRM engine the only TDI head/block that will swap into this car? Finding them to be a bit pricey used in my area. If not, anyone recommend a reliable supplier or is car-part.com my best option? Thanks.
  2. Keithuk
    7,235
    The BRM engine is used in a few VW's
    Manufacturer: VW, Date(s) Used: 01/2005-08/2005, Model: Bora, Engine Code: BRM, 74Kw, 103PS, 1.9 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD)
    Manufacturer: VW, Date(s) Used: 01/2005-04/2007, Model: Jetta, Engine Code: BRM, 74Kw, 103PS, 1.9 Ltr, 4 Cyls, Remarks: Canada ("CDN"), USA ("USA"): Turbocharged Direct Injection Pumpe Düse (TDI-PD)
    Manufacturer: VW, Date(s) Used: 01/2005-08/2005, Model: Jetta/Syncro, Engine Code: BRM, 74Kw, 103PS, 1.9 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD)
    Manufacturer: VW, Date(s) Used: 01/2005-08/2005, Model: Vento, Engine Code: BRM, 74Kw, 103PS, 1.9 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD)
    As taken from my new VAG Engine & Transmission Codes
  3. dbandel
    dbandel New Member
    Dec 3, 2010
    27
    Maryland
    Thanks. Anyone know the differences between the auto and manual equipped BRMs, if any? I noticed a couple of hoses are different but I'd hate to have to swap out a crankshaft if there are differences for the flywheel vs. flex plate.
  4. Ol'Rattler
    Ol'Rattler Well-Known Member
    Apr 24, 2011
    838
    06 TDI Jetta
    Marysvile, WA.
    Why would you replace the engine because of a broken timing belt and run the risk of inheriting someones else's problems? Even if you had to deal with a bent connecting rod, repairing your engine would be a much better and cheaper option.
  5. dbandel
    dbandel New Member
    Dec 3, 2010
    27
    Maryland
    Because it isn't necessarily any less expensive (I was quoted about $1800 for just the head work required due to the damage) or less risky, as my engine would be "inheriting my own problems" as it was getting tired with almost 300k on it. The new one has only about 157k miles. I have had very good luck with used engines from "fresh kills" and this one came from a Jetta that got T-boned, so it wasn't sent to the junk yard due to a mechanical issue (always be wary of junkyard cars that haven't been in an obvious accident) and it also looks to have been well maintained (bearings, cam, lifters, bottom end look good and no sludge in oil, good compression). It came complete with turbo (mine was beginning to leak) for $1300 shipped and with a 90 day warranty. I will keep the old engine and do a complete rebuild on it later for another car anyway, but this also gets this Jetta back on the road sooner.
