2006 jetta ac problems!
Discussion in 'General Diesel Discussion' started by dadio, May 28, 2011.
  1. dadio
    dadio New Member
    Apr 14, 2011
    5
    vw jetta 2005.5
    2006 jetta tdi it takes about 5 miles for the ac to start cooling ? when it starts cooling it good and cold! freon is fully charged. any ideas?
    23,900
    The mk5 AC compressors have a higher than normal failure rate. Basically, the pulley is spinning all teh time, there's an internal valve which controls if the freon is getting compressed. This valve can fail, means you need a new compressor. Any error codes? I don't know if autozone scanners will pick up the climate control module though.
