2005 Passat Wagon Door Lock AND Power Window Problems
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by fasteddie, Mar 12, 2014.
  1. fasteddie
    fasteddie Member
    Feb 15, 2011
    59
    Jetta Wagon TDI 2004, Passat Wagon TDI 2005 & 2004
    Green Bay WI
    Jetta: Frank's TDI cam mod Malone Tune 1. 05 Passat Kerma Colt II cam, 1.5 Malone Tune, sport mode trans 1134. BSM Delete kits on both Passats. Blau suspension on the 04 Passat and Jetta.
    Hi All,
    2005 Passat Wagon TDI, the rear passenger side window is intermittent. The power locks are moving slightly, not unlocking and locking. Connected the VCDS. The driver's door switches all work on the computer. The front passenger door lock switch works on the computer. The outside door lock works on the computer to lock and unlock all doors. However the power locks are not working. Yesterday the passenger side door wind0w would not work at all. Computer states "no communications" rear right.
    The following is from the VCDS:
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Control Module Part Number: 1C0 959 799 C
    Component and/or Version: 80 Komfortgerát HLO 0004
    Software Coding: 00258
    Work Shop Code: WSC 05311
    Additional Info: 1C1959801 80 Tõrsteuer.FS KLO 0202
    Additional Info: 1C1959802 80 Tõrsteuer.BF KLO 0202
    Additional Info: 1C0959811 80 Tõrsteuer.HL KLO 0202
    Additional Info: Steuergerát HR antwortet nicht
    VCID: 37732A1315FE49A66AD-4B32
    6 Faults Found:
    01336 - Data Bus for Comfort System
    37-10 - Faulty - Intermittent
    01334 - Door Control Module; Rear Right (J389)
    49-00 - No Communications
    01331 - Door Control Module; Driver Side (J386)
    49-10 - No Communications - Intermittent
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    27-00 - Implausible Signal
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    00930 - Locking Module for Central Locking; Rear Left (F222)
    Any suggestions?
    Thanks!
    Ed
  2. Oldaccord
    Oldaccord Active Member
    Jan 11, 2014
    661
    1998 Beetle TDI
    BC, Canada
    Maybe broken wires between the car frame and the door? Are all locks working but the rear passenger door? Is there a door speaker in the door, and if so does it work?
  3. fasteddie
    fasteddie Member
    Feb 15, 2011
    59
    Green Bay WI
    Not sure of the speakers. Thought they are working, will check. ALL the locks are not working by any switch, the passenger side front moves a little with any of the switch activations. The VCDS shows the switches working for the lock switches. Would there be a common ground connection? Passenger rear window not working at all.
  4. Love of Passat TDI Wagon
    Love of Passat TDI Wagon New Member
    Jul 15, 2017
    6
    05 Passat TDI wagon. 02 Beetle TDI.
    Wisconsin
    New to this forum. Have similar problem, remote not locking the front passenger door, and sometimes doesn't unlock the rear left passenger door. Been double clicking remote to unlock. Sometimes alarm goes off. Thought issue was due to faulty remote, VW dealership thinks remote is ok, they think problem is in door. Otherwise pretty much that's all that's wrong on car. Runs beautifully.
  5. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,550
    85 kubvan
    so... ill be an arss... if the remote unlocks any door.. how is it bad?? the idea of double tap for rest of doors is so they do not unlock letting that weird person from getting in that walking past one of the other doors as you try to get in your car... so the issue to me sounds like a ccm issue as its 2 doors acting up... if 1 door then id say wiring issue... or the locking servo is failing.. vagcom the ccm
