2005 passat fell on its face
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by oldschool, Jun 25, 2012.
  1. oldschool
    oldschool New Member
    Jun 23, 2012
    tdi beetle tdi passat
    Hi all, I'm a first timer here. My wife's Passat was running bad, I took it out and "stood on it" and it fell on it's face, I popped off the timing belt cover and it looked OK, it acted like no fuel , so I replaced the tandem pump. after LOTS of cranking and a little either the best I could get it to do was backfire. So I went back to square one and checked the timing belt... yep...this time I found a missing tooth so I'm doing a timing belt now. Got to get back to work, I'll let you know how it goes.
    Oldschool
    23,767
    welcometomyturbodies
    Warning: missing tooth often = slipped sprocket. Set engine to TDC and if it's off it's possible you also need to remove-repair head. also check out new buying guide for other catch up maintenance.
