2005.5 jetta tdi timeing belt replacement
Discussion in 'Ross Tech VCDS forum' started by dadio, Apr 14, 2011.
  1. dadio
    dadio New Member
    Apr 14, 2011
    5
    vw jetta 2005.5
    i have a 2005.5 jetta tdi need info on how to install new belt ,it has jumped timeing
    23,757
    Be careful, if it jumped timing there's a good possibility that the valves have crashed into the head. Here are timing belt instructions: http://www.myturbodiesel.com/1000q/a5/brm-VW-Jetta-TDI-timing-belt-replacement-1.htm
    Here are head replacement instructions for an earlier engine, the BRM procedure is similar: http://www.myturbodiesel.com/1000q/a4/cylinder-head-removal-ALH-TDI-engine.htm At least check for damaged lifters . These are interference engines and a compression check may not show damage since the valves point up-down.
  3. dadio
    dadio New Member
    Apr 14, 2011
    5
    vw jetta 2005.5
    looks like head is damaged,where can i find engine info ,code,is this a BRM engine
  4. Fluid
    Fluid New Member
    Jan 17, 2008
    482
