2004 jetta cranks but wont start
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by Grant, Jun 20, 2013.
  1. Grant
    Grant Member
    May 12, 2013
    31
    2004 jetta tdi
    I have a 2004 jetta and have been having problems for two weeks now. At first the car would start the first time starting it of a morning. Then it would just sit and crank if I tried starting it while the engine still had heat built up. I have been trying to figure out the problem and now the last couple of days the car will not start at all. Could someone help lead me in the right direction to fix this?
    23,902
    1. error codes
    2. timing belt timing?
    3. recent maintenance?
    I've heard of bad ECU causing these weird problems but start with easy/cheap stuff first.
  3. Grant
    Grant Member
    May 12, 2013
    31
    2004 jetta tdi
    I haven't checked the error codes yet, i do not know what the timing belt timing is and the recent maintenance is new fuel filter new air filter and crank sensor. I was having trouble with it dying while driving the car for over a 30 minutes or so but always started right back up. Replaced the crank sensor and was fine for 3 weeks and then this started.
  4. markbar1
    markbar1 New Member
    Jun 23, 2013
    2002 jetta
    check your fuel filter, it may be clogged!
  5. Grant
    Grant Member
    May 12, 2013
    31
    2004 jetta tdi
    The fuel filter is only a month old
