2002 golf tdi
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by K_zibit, Jul 10, 2012.
  1. K_zibit
    K_zibit New Member
    Jul 10, 2012
    2002 vw golf tdi
  2. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,089
    Jetta 2003, Golf 2001
    welcometomyturbodies Welcome to the website!
    Getting a proper so-called "tune" (essentially a re-map of the car's computer software) is far preferred to these add-on boxes... (I'm too tired to go into details at this time, but... if you do a search...)
    However: please keep in mind that a general rule-of-thumb with these cars is that if you can't verify that a complete and proper timing belt system change has not been performed in the recent past on any new-to-you TDI, you make sure to have it done ASAP - before you think of any power or cosmetic modifications...
    Please go over the procedure in order to see how it should be done:
    http://www.myturbodiesel.com/1000q/a4/ALH-engine-timing-belt-change-VW-Jetta-TDI-1.htm
    http://www.myturbodiesel.com/forum/...-new-beetle-golf-alh-engine-1998-2003-a-2976/ and see http://www3.ns.sympatico.ca/roseland/VWPartsA4.htm to see what parts should be replaced.
    Sorry I don't know of any local-to-you TDI tech that I could recommend...
    All the best,
    Yuri
  3. K_zibit
    K_zibit New Member
    Jul 10, 2012
    2002 vw golf tdi
    Yea
    Yeah the timing bel was done 20,000 km Ago with water pump and new Ac pump
    That's for the info man
