2000 VW Jetta TDI Clutch size questions
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by Gstank, Dec 18, 2016.
  1. Gstank
    Gstank New Member
    Dec 18, 2016
    2000 Jetta TDI
    Flint, MI
    Aftermarket 5th gear (.658)
    Hello,
    I am the proud new owner of a 2000 Jetta TDI, haven't had any issues until recently. This morning while backing out of my driveway i suspect my throw out bearing seized and thus resulting in my slave cylinder dying. Vehicle has 350xxx miles on it and i figure while i'm in there i should probably replace clutch/flywheel as well. My only question is how do i know what size clutch/flywheel i need? From what i've seen there is a 8 5/8 inch and a 9 inch option.
    TIA
    Greg
    23,902
    Considering the mileage, I would. Give a vendor your VIN or year and they should be able to tell you. Where do you see the option?
  3. BOWZ
    BOWZ Member
    Apr 20, 2013
    69
    2001 JETTA
    SOUTHFIELD, MI
    MALONE STAGE 4, 1019 DLC, VNT17, EGT BOOST, 3" DP W/2.5" CUSTOM EXHAST,PANZER PLATE, SBC STAGE 2 DD, .658
    I didn't have a choice on my 01 Jetta. I do however love my South Bend STG2 Daily! Good Luck!
    Bowz
  4. Gstank
    Gstank New Member
    Dec 18, 2016
    2000 Jetta TDI
    Flint, MI
    I ended up taking a good look at the clutch disk and there was plenty of material left on it (lucky me) but i did not remember to measure the size, most likely i will either call the dealer or my local import parts store to get the size from them. The different sizes i saw were on rockauto since I'm able to do the work myself I don't feel the need to go to shops but I always like getting the best price I can
  5. Keithuk
    7,235
    I've checked ETKA to see what it says on centre plate size for a USA Jetta TDI.
    Clutch plate for vehicles with glow plug heater ALH - LUK 219mm - 028 141 36 LX - £123
    Clutch plate for vehicles with glow plug heater ALH - F&S 228mm - 038 141 36 DX - £114 was dropped on 01/10/2007 for 038 141 33 CX - £114
    They do a 1 set clutch parts - ALH - LUK 220mm only for 028 105 264 J, 028 105 264 K, 038 105 264 J
    Clutch plate - 028 141 036 LX - £123
    Clutch pressure plate - 028 141 025 PX - £120
    Release bearing - 02A 141 165 M - £44
    You normally replace all 3 main parts when you do a clutch change not just the centre plate.
    This is the only part number that shows in http://nemiga.com/cat_spares/etka/volkswagen/jem/204u/141500/
    You need to keep http://nemiga.com/cat_spares/etka/volkswagen/ in your favorites/bookmarks.
  6. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,550
    85 kubvan
    so keith... why different sizes??
    i figured one is smf other dmf..
    smf is 228mm (euro parts.. not MADE IN USA)... and i do not know of bigger
