2000 Jetta TDI Overheating
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by ImXCanadianXEh, Dec 12, 2017.
  1. ImXCanadianXEh
    ImXCanadianXEh New Member
    Dec 12, 2016
    2000 Volkswagen Jetta TDI
    Fort Erie, ON
    VNT 17/22, Bosio Race 520, Stage 3 Malone Tune, EGR Delete
    I have 2x 2003 Jetta Wagon TDI's
    Recently had the timing belt, water pump, studs, etc replaced.
    both have seemed to devolp the same problem since then.
    They both seem to overheat, Have since then replaced the radiator, thermostat 3 times (All 3 Replaced with OEM Thermostat)
    Burped the coolant system, confirmed hose's are routed properly, Burped coolant system again, and still overheating. and lower radiator hose staying cold.
    Any Insight on what it could be
    Both car's had the Hepu timing belt kit installed
    its getting really frustrating
  2. oil rides
    oil rides New Member
    Apr 3, 2016
    15
    VW Jetta 1999
    Storrs, CT
    Maybe try it out without a thermostat see if the lower hose gets warm
  3. Dave N
    Dave N Member
    May 31, 2015
    71
    06 Golf TDI BEW 09A
    Spokane Wa
    You don't put the thermostat in backwards by chance did you?
  4. mgoff5000
    mgoff5000 Member
    Feb 27, 2012
    232
    2000 Jetta 5-spd, 2004 Passat Wagon
    SF Bay Area
    Jetta is on H&R Sport/Koni Yellows, Skid plates on Jetta/Passat, BSD and cam replaced on Passat
    If this developed in BOTH cars after having the same maintenance done then I've got to suspect either the kit or the work. That's just really low odds that something else went wrong on both cars.
  5. ImXCanadianXEh
    Dec 12, 2016
    Fort Erie, ON
    The one car I did a heater core flush on, and fixed the issue. The other not so much luck :(
    Trying to avoid replacing water pump but pulled off coolant line the one car was steady stream at idle, the other was kinda just intermediate
