1998 VW Jetta TDI Low Power
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by dieselvw, Nov 10, 2010.
  1. dieselvw
    dieselvw New Member
    Nov 10, 2010
    1998 VW Jetta TDI
    My 1998 VW Jetta TDI has 214,000 miles on it. Gradually it started to produce heavier and heavier black smoke. I had the intake manifold removed and it was full of oily carbonized soot. After cleaning the car quit smoking and mileage improved. However the engine hesitates and smokes a little more with the MAF sensor plugged in. Unplugging the MAF sensor allows the car to run clean with no hesitation. However with or without the MAF the car has minimal power. Generally it is still fine for around town but acceleration on the freeway is slower than it should be. I can still drive at 70 or 80 just fine. Haven't tried any faster. I replaced the MAF, but no change in behavior, so I have left the sensor unplugged. Air filter is fine.
    I'm thinking wastegate valve, EGR valve, or turbo charger could need cleaning or replacement.
    This car has always been a good running vehicle with great fuel mileage. Any thoughts or other ideas.
    23,891
  3. dieselherb1
    dieselherb1 Member
    Nov 10, 2010
    53
    96,2 97Passats,98,2000 Jettas,3 81 Rabbit pickups, 95 Chevy pickup diesel
    Could also be the pressure hoses that go to the N75 valve and also to the ECM
  4. David Embree
    David Embree New Member
    Nov 12, 2010
    1998 jetta TDI
    cleaned intake tdi
    welcometomyturbodies
    First post here andd happy to be a member. We cleaned our 1i
    intake at 145,000 and were rewarded with the ability to climb hills again in gears higher than 2nd.
    amazing the government re-burn requirments are so expensive to purchase and maintain with questional results. Thanks to all who contribuite to the forms.
