1994 mk3 jetta/vento central locking
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by m2rekkk, Aug 30, 2010.
  1. m2rekkk
    m2rekkk New Member
    Aug 30, 2010
    I have a problem with my central locking system/ alarm. When I try to lock my doors from the driver's side it only locks the drivers door. But if I try to open it then it opens all the doors. Same problem goes with my passanger door.
    There is also a problem locking/unlocking doors remotly. It never works on the first time i click, usually it works on the third try. Its like the vacuum pump gets the signal because it makes a short noise and the lights also blink but thats it. Im using WAECO MT150.
    I alredy checked the vacuum hoses and I didnt spot any leaks.
    Sorry for my grammer and I hope someone can help me with my problem.
    23,882
    Did you check the vacuum hoses in the door wiring boot? Did you check the wiring to make sure it hasn't cracked? There should be a rubber boot in the door hinge. Slide it back and carefully inspect all the wiring.
    Have a helper press the remote while you look at the vacuum pump. Maybe it's bad and can only go one way.
  3. 6eggs
    6eggs New Member
    Aug 10, 2007
    114
    none
    Wyo
    Is a WAECO MT150 an aftermarket remote?
  4. m2rekkk
    m2rekkk New Member
    Aug 30, 2010
    The wiring and the hoses seemed okay in the door wiring boot's.
    Also yes the WAECO MT150 should be an aftrermarket remote but i don't think that the problem is with it because the vacuum pump gets the signal when i click on the remote.
  5. 6eggs
    6eggs New Member
    Aug 10, 2007
    114
    none
    Wyo
    Chitty, do you know how to check the vacuum pump?
  6. Tastes like Diesel
    Tastes like Diesel New Member
    Sep 20, 2010
    1996 Jetta TD
    central locking
    I would imagine that checking all the plastic lines for leaks could be tough to do visually. Perhaps if you have a Mity Vac you could tap into the lines and see if you can a) make the locks work and b) see if the vacuum holds. I would think you could also put a vacuum gage on the pump, unfortunately I don't have the specs for this.
    I recently repaired my own car and discovered that a line had let go at one of the connectors inside the door jamb area. The other observation that I made was that the pump would run for 10-20 seconds when activated. I'd be a bit concerned if you pump only come on for a second or two.
