19" Savannah wheels
Discussion in '2012-2016 VW Passat TDI forum' started by TDI_Brad, Dec 9, 2011.
  1. TDI_Brad
    TDI_Brad Member
    Oct 23, 2011
    208
    2012 Passat TDI SEL
    Cool Stuff
    Savannah light alloy wheels anthracite
    Wheel size: 9J x 19, ET33, LK 5/112
    Tyre size: 255/40 R19
    Colour: anthracite with ground flange and matt varnish.
    Part no. 5N0 071 499 AX7
    Can anyone tell me if these will fit the Passat.
  2. tcm glx
    tcm glx New Member
    Oct 3, 2011
    62
    2012 Passat TDI
    Et 33 is a bit aggressive.
  3. TDI_Brad
    TDI_Brad Member
    Oct 23, 2011
    208
    2012 Passat TDI SEL
    Cool Stuff
    That's the reason I asked I don't really understand these wheel sizes.
  4. tcm glx
    tcm glx New Member
    Oct 3, 2011
    62
    2012 Passat TDI
    I am running a 19x8 replica with a 45mm offset and 255/40/19.
    The 33 mm offset means it will stick out another 12mm. Mine re pretty much right to the edge of the fender. It will be tight, if you don't plan on lowering, you may be able to pull it off.
  5. TDI_Brad
    TDI_Brad Member
    Oct 23, 2011
    208
    2012 Passat TDI SEL
    Cool Stuff
    Well I don't want them past the out fender but with right wheels I don't think I will need to lower it. But if I did I wouldn't go too low. The hr springs go about an inch right? I would rather do wheels first for now. I saw them on this Scirocco and figured if they fit on that they may work for me.
  6. TDI_Brad
    TDI_Brad Member
    Oct 23, 2011
    208
    2012 Passat TDI SEL
    Cool Stuff
    So this B7 is on coil overs and Q7 replicas from discount tire direct. 20x9 et40. Ventus V12 Evo 245/30/20 tires. [​IMG]
    So for our cars fitment do we need more or less offset? I'm confused if et33 is too aggressive and will be past the fenders it seems like these 20 x 9 et40 rims would stick out further. Either way the Q7s look dam sweet on this car and I the savannah rims would too.
  7. tcm glx
    tcm glx New Member
    Oct 3, 2011
    62
    2012 Passat TDI
    Let me see if I can explain without muddying up the waters.....
    Offset means the wheel sits further in, or further out from center line. So for example, a 20x9" wheel, with 0mm offset bolts to the hub with 4.5" to the inside and 4.5" to the outside (from the hub). When you add +40mm offset, it goes further inside the wheel wheel. So a 33MM offset sits further out than a 40MM by 7MM. Now this is only true if both wheels are the same width. You have to take that into account.
  8. TDI_Brad
    TDI_Brad Member
    Oct 23, 2011
    208
    2012 Passat TDI SEL
    Cool Stuff
    So what would be a suitable range in offset for the B7?
  9. dgc
    dgc New Member
    Dec 19, 2011
    6
    Jetta
    What is the weight of these wheels comparied to the stock 18" wheels?
  10. dgc
    dgc New Member
    Dec 19, 2011
    6
    Jetta
    How much was this lowered?
  11. TDI_Brad
    TDI_Brad Member
    Oct 23, 2011
    208
    2012 Passat TDI SEL
    Cool Stuff
  12. dgc
    dgc New Member
    Dec 19, 2011
    6
    Jetta
    Thanks Brad, guess i have more reading to do, I have been trying to find specs. on the stock 18 wheels but can seem to find anything when you looked at the Savannah did you find any specs.?
  13. TDI_Brad
    TDI_Brad Member
    Oct 23, 2011
    208
    2012 Passat TDI SEL
    Cool Stuff
    No just that it 5x112 et 33 no weight
