15" and 16" Audi OEM Wheels 5x112 Bolt Pattern Corretion
Discussion in 'site comments/suggestions/corrections' started by huvw42, May 1, 2012.
  1. huvw42
    huvw42 Member
    Feb 4, 2011
    55
    2005 Passat 1.9 TDI 4Motion
    Hungary
    The diameter for the Audi Artis is incorrectly listed as 15" when it is actually a 16" wheel.
    www.original-felgen.com
    23,767
    thank you!
    VW-Audi made many wheels in multiple sizes so I'll just double check this before changing the wheel gallery.
  3. snorlax
    snorlax New Member
    Mar 3, 2010
    29
    The center cap listed is the correct Audi cap.
    I got a set of these last fall and found that the VW center cap that fits is 3D0 601 165 BXF. I had a set of 3B7 601 171 from a new GTI and altered them to fit - the 3 mm black plastic edge on the face of the cap has to be cut back to the silver VW emblem, a PITA but they fit tight and looked nicer than the Wellington / Road america caps by eliminating the black plastic ring.
    The wheel also weighs 23 lbs. :)
  4. chittychittybangbang
    23,767
    So it really is a 15" wheel or did you find a 16" one?
  5. dot4line
    dot4line New Member
    May 31, 2012
    touareg
  6. huvw42
    huvw42 Member
    Feb 4, 2011
    55
    Hungary
    Check out the third photo in the advertisement...
    Artis
  7. huvw42
    huvw42 Member
    Feb 4, 2011
    55
    Hungary
    One more for 16"...Artis
  8. chittychittybangbang
    23,767
    I was away on vacation and I'm back. Fixed now, thanks for your reminder!
  9. huvw42
    huvw42 Member
    Feb 4, 2011
    55
    Hungary
    Audi 16" "Dynamic" wheel
    I just acquired a set of these:
    [​IMG]
    Your information in the wheel data base is correct in relation to the 7.5" version, which is what I have. The weight with center cap and valve stem is 17.4 pounds. And the tire which was originally mounted on it was a 225/55R16.
    I was reviewing an A4 brochure and notice the name of this particular wheel style is "Dynamic."
  10. chittychittybangbang
    23,767
    thanks, will check the FAQ and add any notes or that pic.
