130000k mile vw golf mkiv rebuild. what to replace?
Discussion in 'General Diesel Discussion' started by drhankinbush, Feb 14, 2012.
  1. drhankinbush
    drhankinbush New Member
    Feb 14, 2012
    golf/2001
    hello everyone! first post for me. i have a 2001 golf 2.0mkiv that i recently decided tp rebuild for long term future survival. it presented with so many of the typical problems--stalling, slow coolant leak, coolant temp sensor issues, maf issues plus wear and tear-really rough suspension, clutch wear, and right cv joint noise.
    so far, i have replaced the maf, the o2 sensors, the catalytic converter and exhaust flanges and cleaned the tb + vagcom tb adaptation.
    i have replaced the clutch, the coolant reservoir, the cap, the coolant temp sensor and the flange connecting it to the engine. i have started rebuilding suspension with shocks and springs, tie rods, ball joints and soon, the control arm bushings.
    i have also changed the transmission oil.
    i love the car and want to make it live as long as possible. so my question is, what else would you replace to make it last forever?
    thanks!
  2. larrysmiths1
    larrysmiths1 Member
    Jan 18, 2011
    36
    '89 cabrio
    a few... cam,header, ss exhaust,suspension, short
    the knibbler pin!
  3. dezel
    dezel Member
    Jan 5, 2011
    157
    02 jetta tdi leather gls
    Kerma chip & Bosio 520 nozzles
    Are you getting codes or problems that necessitate replacing the exhaust? On my 02 I recently had to do a cv axle,did both got them from raxles, lifetime warranity. I have already done battery & alternater. The car still has orig. front brakes just did rear. I would only replace whats needed 130,000 is not many miles. Focus on wear items brakes,timing belt,oil changes, fluids, 109 relay,clean intake etc. Look in the Faq section good info. What type of mileage are you getting?
  4. Calidris96
    Calidris96 New Member
    Aug 5, 2010
    16
    2003 Jetta GLS TDI Wagon
    Montgomery, Texas
    Sigma-5 shifter, Panzer FMJ, Koni FSDs, towing springs, KermaTDI tune, Bosio DLC 1019, hula dancer
    I was looking for similar information and found some good things to watch out for in the buyers guide.
  5. Keithuk
    6,910
    Autodata.
    Golf/Golf Estate (98-06) 1,9D TDI 1997-02
    Timing belt - Renew Every 60000 miles or 48 months
    130k Sevice
    Engine oil Drain/refill
    Engine oil filter Renew
    Diesel fuel filter Drain. Renew every 20k
    Pollen filter, if fitted Renew every 20k
    Front brake pads Check/report
    Front brake discs Check/report
    Rear brake pads Check/report
    Rear brake discs Check/report
    Brake linings through inspection hole Check
    Timing belt Check/report
    Service interval indicator Reset
    Nothing Major at all just a visual check on everything.
