The dealer blamed the oil I was using by saying it was too thin, but then others say a heavier weight is not good for the PD TDI. I have run other diesels on regular 20-40 weight for years with no wear issues. Since I started using synthetic oils in this TDI and checking with others that use it in both gas and diesel engines, it seems to me that they are experiencing premature wear on various internal parts. As always, I am opened to any thoughts/opinions. T21 |
There are 5w-40 505.01 oils that I use. Lubro moly. CI rated oil, compression ignition, have some more detergents. I don't know what's special about 505.01 spec specifically and whatever it is, it didn't work. But since there is a 5w-40 in 505.01 that's what I use.
Mobil 1 TDT, Rotella T-6 or other quality 5-40 diesel oils and you will be good. I worry less about the VW rating and more about it being a quality oil. Pentosin HP II is another...
Shell Rotella T6 5w-40 is good to use.
Bang for the buck- Shell rotella T6- excellent oil and easy to obtain
