Old 01-17-2012, 04:08 PM
Car: 2012 Golf TDI
Default SOHC or DOHC?
According to VW, the 2012 Passat TDI features a DOHC powerplant:
Double overhead camshaft, spur belt driven, four valves per cylinder, maintenance free hydraulic lifters, single valve springs
Whereas, the 2012 Golf TDI is described as having a SOHC powerplant:
Single overhead camshaft, spur belt driven, four valves per cylinder, maintenance free hydraulic lifters, single valve springs
The FAQ here states the Golf's engine as being revised to feature 2 overhead cams. I'm assuming then that VW's website is wrong as I also thought both the Passat and Golf TDI's have the exact same engine. Am I correct in my assumption?
Old 01-17-2012, 11:50 PM
Which article are you reading in the FAQ?
All 2009+ 4 cylinder TDI engines sold in the US are DOHC. 100% sure the golf TDI is not SOHC. VW's website has a bunch of errors. I seem to recall some sportwagen specs are still listed as "TBD" even though the car's been out for years.
Old 01-18-2012, 06:54 PM
Car: 2012 Golf TDI
I don't recall the exact FAQ, but I do know it was from this website.
As for the errors on the website, that's what I thought. Thanks for the clarification.
Old 01-20-2012, 09:36 PM
Car: VW Jetta / 2010
Default Cam Drive Belt
Why do they use those rubber drive belts now instead of the chains? Didnt the chains work well? and you never had to change one...is it just a scam to get you back into the garage?
Old 01-21-2012, 08:16 AM
Car: 2012 Golf TDI
Good question and I too would like to know. I prefer timing chains. I can deal with a bit of stretch over the years instead of having to replace a belt. I've done belt jobs on a few of my other cars I've owned in the past and it's something I'm not exactly thrilled to do as it usually involves losing an entire Saturday or Sunday.
Old 01-21-2012, 10:08 AM
Vw's diesels have been using belts for many years and VW doesn't have a good history with chains so you're better off this way. 1 belt change every 120k miles in your case is pretty good considering belts used to only last 60k miles.
Also, most VW-Audi designs require you to remove the transmission and a bunch of stuff to replace the chain, if a car goes 300,000 miles, it's probably a wash in terms of maintenance costs but I think it's a little cheaper to build. For example, cost to replace timing chain on an Audi v8 engine is about $8000 at dealer. Cost to replace TB on a TDI is about $1200 at dealer. It can be done in under 1 day in driveway for sure, chain can't.
