First post on this form Have retro fitted a VW bluetooth kit to my T5 transporter 2010, can't seem to get the thing working, I get to the phone menu in the mfd and it seems to freeze up I can't select the phone search or help options or exit the phone menu without unpluging the blutooth kit Not using the mfsw, just the stalk buttons and he kit is 3C8 035 730A Any help appreciated and sorry if this is in the wrong place Thanks |
Also I can't understand why I would be getting all these faults, Maybe the box is faulty
Address 77: Telephone Labels: 3C0-035-730.lbl Control Module Part Number: 3C8 035 730 A HW: 3C8 035 730 A Component and/or Version: Telefon 007 0078 Software Coding: 020000000000000000000000 Work Shop Code: WSC 00000 000 00000 ASAM Dataset: EV_UHVPremi A01005 (VN75) VCID: 2142607281A1 5 Faults Found: 9455635 - Telephone Microphone B1048 13 [009] - Open Circuit Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 43 Mileage: 16487 km Date: 2013.14.17 Time: 10:48:27 9458451 - Cellular Antenna: B1053 13 [009] - Open Circuit Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 43 Mileage: 16487 km Date: 2013.14.17 Time: 10:48:27 9457939 - Telephone baseplate B1051 13 [009] - Open Circuit Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 43 Mileage: 16487 km Date: 2013.14.17 Time: 10:48:27 9458193 - Control Module for Cellular Telephone B1052 14 [009] - Short to Ground Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 43 Mileage: 16487 km Date: 2013.14.17 Time: 10:48:27 13636352 - Control Module Not Coded U1013 00 [009] - - Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 43 Mileage: 16487 km Date: 2013.14.17 Time: 10:48:27 |
I'm not sure but barring a defect, my guess is that there is a problem with the control module coding and installation. It may have not been plug-play.
Thanks for the reply
Ive found very little about the coding but managed to find this below and copied the coding, I thought I'd cracked it because it cleared the faults but when I went in again it brought 3 faults back and the mfd still just freezes up Address 77: Telephone (J412) Labels: 3C0-035-730.lbl Part No SW: 3C8 035 730 A HW: 3C8 035 730 A Component: Telefon 007 0078 Revision: -------- Serial number: 35909603008345 Coding: 020000000100000000010000 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_UHVPremi A01005 ROD: EV_UHVPremi.rod |
Try posting your scan in the ross tech section at the top of this subforum. It will get their attention and they may know the correct coding. Make sure the title has your model and year in addition to the problem to be more descriptive.
Thanks I will try that
Think I'm going to swap the box first though with the suppliers and see from there Thanks |
Found a bit of info regarding coding but still no Joy
Code should be something like 020000010100010000000400 found long coding labels and pasted them into the label file, translated them - ,00,Keine fallback language LC, 00, 0 ~ 7, 01, English LC, 00, 0 ~ 7, 02, English LC, 00, 0 ~ 7, 03, French LC, 00, 0 ~ 7, 05, Italian LC, 00, 0 ~ 7, 06, Portuguese LC, 00, 0 ~ 7, 08, Tschechie LC, 01, 0 ~ 7, 00, voice control active LC, 01, 0 ~ 7, 01, no language service LC, 02, 0 ~ 7, 00, audio parameter set microphone type VW 1 LC, 02, 0 ~ 7, 01, audio parameter set microphone type VW 2 LC, 02, 0 ~ 7, 02, audio parameter set microphone type VW 3 LC, 02, 0 ~ 7, 03, audio parameter set microphone type VW 4 LC, 02, 0 ~ 7, 10, audio parameter set microphone type Audi 1 LC, 02, 0 ~ 7, 11, audio parameter set microphone type Audi 2 LC, 02, 0 ~ 7, 12, audio parameter set microphone type Audi 3 LC, 02, 0 ~ 7, 13, audio parameter set microphone type Audi 4 LC, 03, 0 ~ 7, 00, active antenna diagnostic LC, 03, 0 ~ 7, 01, antenna diagnostic off when disabled LC, 04, 0 ~ 7, 00, baseplate active monitoring LC, 04, 0 ~ 7, 01, monitoring baseplate off when disabled LC, 05, 0 ~ 7, 00, cooperative mute active LC, 05, 0 ~ 7, 01, cooperative mute off when disabled LC, 06, 0 ~ 7, 00, 3 button module active / SMS write possible LC, 06, 0 ~ 7, 01, 3 button module deaktiv / SMS write possible LC, 06, 0 ~ 7, 10, 3 button module active / SMS write not possible LC, 06, 0 ~ 7, 11, 3-button module deaktiv / SMS write not possible LC, 07, 0 ~ 7, 00, BT-audio active / active multimedia media context LC, 07, 0 ~ 7, 01, BT-audio off when disabled / Active multimedia media context LC, 07, 0 ~ 7, 10, BT-audio active / multi media context off when disabled LC, 07, 0 ~ 7, 11, BT-audio off when disabled / multi media context off when disabled LC, 08, 0 ~ 7, 00, THB cradle installed LC, 08, 0 ~ 7, 01, VDA cradle installed LC, 08, 0 ~ 7, 10, Paragon cradle installed LC, 09, 0 ~ 7, 00, cry for help disabled LC, 09, 0 ~ 7, 01, cry for help enabled (not supported!) LC, 10, 0 ~ 7, 01, fuel type petrol LC, 10, 0 ~ 7, 04, fuel type diesel LC, 10, 0 ~ 7, 05 LPG fuel type LC, 10, 0 ~ 7, 06, natural gas fuel type LC, 10, 0 ~ 7, 08, fuel type, electric LC, 10, 0 ~ 7, 10, hydrogen fuel type LC, 11, 0 ~ 7, 00, category (unknown) |
