any ideas on this one,my egr valve was completely blocked at the port to inlet manifold,all cleaned and the valve seems in good order.Engine rattles like a valve knock even after valve cleaned.took vacuum line off and no vac even at high revs,vac pipe goes to the egr solenoid valve which also i believe sens a vac to the turbo gate valve/booster.if the combustion was too lean,can this cause the valve knock problem,it has progressed over the last 3 months with max rpm 4500,before the knocking noise it would rev up to 5800.I am going to get a new egr solenoid valve,if anyone has had similar please let ne know
