Old 08-30-2010, 10:10 AM
Default Free EOBD II Error Codes software
Hi guys/gals.
Anyway a few months ago I printed out all the data from Autodata for the Golf 2.0 TDI 2009 because that was the closest vehicle to mine. All the Error code printed out and it took an hour and a half 140 sheets, slow network printer. Some of you my know I make programmes as a hobby so I thought it would be a good idea to put all these VAG, EOBD II, Fault location and Possible causes 5680 into a database. Now I'm not sure if the ECU displays the actual error code or you just take it to the dealer for a VAG-COM check.
Now I started of typing everything into the database with a bit of copy and paste as some items were repeated, I did about 350-400. Even though I've had computers since 1981 I'm still a two fingered typist. At work we use Autodata its normally £660 each year but we get that at half price because we are a College. Our license runs from April to April and we were having trouble sorting things out. I rang Autodata and they said we could use the online version of Autodata while we sorted the problems out. They sent me the info and it works great. I checked on my Golf GTD 2010 and its listed, great. Because these are web pages you can select all and copy everything into a Word doc which I did. Now it was easier and a lot quicker just to copy and paste into the database, it still took me a week to do that.
Our own new version came a few days later and it was installed on one of our servers. I checked my car again and its not listed, it only lists Golf 2.0 TDI 2010 as before. I rang Autodata and asked how come the online version has my new car but the new server version doesn't? They said the online version is updated monthly. I said ok but my car came out April 2009 and it wasn't on the old version. I had some bumbling excuse.
Sorry to bore you with these trivial details back to the main point of this topic. If anyone is interested in this programme I've made please make a comment. I'm not sure it will suit everyone. I know you can get error code online Ross-Tech. OBD II Code but you have to click on a number change page read it/print it then move back for another number which is slow. Plus you have to be online to access anything.
You can search the database for any VAG or EOBD II error number, Fault location and Possible causes, words or numbers. The simple thing is its a database so any code can be added later. Don't think you can add your own data you can't it deletes the database afterwards. If you find any good sites with code I can add them.
The more users that want it the more chance of me posting it.
Its FREE.
Old 08-30-2010, 12:23 PM
Moved to the general forum for greater visibility and added the code word
Click here to go to the post where the software can be downloaded
Old 08-30-2010, 01:18 PM
Free? Sure. Is it an access database?
Old 08-30-2010, 01:29 PM
Free? Sure - Isn't it amazing how people always want things for free?
Yes it uses an Access 2003 database but as I said before you can't edit it and add your own codes because it deletes the database when the app closes.
@chittychittybangbang - Cheers I wasn't sure which one is the most read.
Old 09-01-2010, 03:59 PM
I'd be interested. Do you need access to use it? Are there any free access readers?
Old 09-02-2010, 08:41 AM
No you don't need Office or Access installed because it uses dao360.dll to access the database. Just check in Program Files\Common Files\Microsoft Shared\DAO\ folder if its there. If it isn't then you can download an update of M$ to put it in. If you're using WinXP/Vista it should already be in there.
Old 09-11-2010, 03:19 AM
I'd like to see it too. It sounds interesting.
Old 09-11-2010, 05:26 PM
Ok guys.
I'm having a problem with the zip attachment. The message says
Your file of 596.0 KB bytes exceeds the forum's limit of 97.7 KB for this filetype. I can't split it down smaller as the exe alone is 2,128Kb because the database an help file are both inbuilt.
Unless chitty can increase my upload limit then you won't be able to see the app sorry.
Old 09-11-2010, 07:45 PM
Sorry, the upload limit is set across user groups and I don't want everyone to be able to post huge files. Please email it to me, PM sent with more details.
Old 09-12-2010, 10:11 AM
Ok I've just emailed the zip file to you. Where ever you put this file please add the comment that you need to read the ReadMe First.txt first that will give them basic instructions what to do.
There were 5680 error codes originally but I've added the ones from the Ross-Tech site and shown additional copywrite to them, there are now 5942 error codes.
Catch you later.
