Where is it leaking out, past the cap?
First, what are you filling it up with? Don't mix VW's coolant with the green stuff since they can foam or sludge. If you start the cold engine for a little bit and remove the cap, is there any pressure in the expansion tank? |
I am running pink long life and I have not I have not check for pressure after start up when it is cold and I check the oil and add antifreeze there is pressure
Lol I had a laugh at your thread title,anyway, try feeling around the coolant hoses when the car is cold or just warm, around the clips I'm thinking because they can bite in and cause a slight split. If you look as to where the coolant puddle is in relation to where the car sits too, is it to the right of the engine or the left? Is it towards the front or rear? It might also be seeping from somewhere then running along a coolant pipe, the other thing is around any flanges or housings that connect to the head or block, there might be signs around them although I expect it's a bit tricky in the beetle for space. You just have to persevere but you'll get there.
The only place it can get pressure is the block, normally this is a bad head gasket. Again, this is on a cold engine. It hasn't got hot enough to pressurize the system. Once it's warm it should be under pressure. |
