No, the head gasket is between the cylinder head and engine block. The camshaft is what opens the valves and moves the actuators. Completely separate things. Perhaps they meant valve cover gasket - this gasket is reusable. Here are instructions on how to do it: http://www.myturbodiesel.com/1000q/m...ace-vw-tdi.htm
what you do need to replace is the one time use factory cam cap and injector rocker hold down bolts. there are kits available from franko6 and bleachedbora that are cheaper than the factory bolts, and are reuseable.
you def want a set of those.
~Aaron~ Google Voice Cell (216)2 GLR TDI (216.245.7834) Growler's TDI Service Available Weekends in Columbus, OH. est. 1/2009 Here is a link to My Availability Calendar 2003 ALH Jetta wagon 5m. RC3, T4s, Wavetrac LSD, 3.16 R&P, DG SS, 3" TT Turboback, Steel skidplate with Mogolf Mod. VR6 Springs and Koni FSDs. |
Sorry I should have been more specific I was told that when removing the camshaft the bolts go through the cylinder head and into the block so there is a chance of a head gasket leak just wondering if this is true I cant see a problem but just thought if someone had done the job before they could offer me some advice
Thanks for the post, went over it seems straight forward. A car wrecker I use told me that was the case with the head gasket I guess he was trying to sell a head gasket job. I will be doing the job tomorrow so hopefully everything goes well. Thanks again for the help.
Thanks for the FYI
