Originally Posted by chittychittybangbang
Doesn't the tiguan already have bluetooth? If lower blueooth see here: http://www.myturbodiesel.com/1000q/a...W-Golf-JSW.htm to install high bluetooth. Very easy.
RNS-510 install is pretty easy and fast. I don't know how to remove the trim on Tiguan but it should be pretty easy. RVC would require some wiring, do you plan to install OEM RVC or aftermarket?
The Tiguan does have Bluetooth, however because I have the RNS-315, the bluetooth is built into the 315. Once I upgrade to the 510, I will lose bluetooth, that is why I want to upgrade to the 9w7. I am getting a kit which includes the 9w7, styrofoam holder and wiring harness. I was told installing it is fairly simple. You just run a wire from the microphone in the overhead console to the harness. The harness then runs from the RNS510, behind the glovebox and then under the passanger seat. I was told it's about 15 min of install time.
I have a walk though on removing the trim on the tiguan to do the RNS-510 install. It is very straightforward.
The RVC kit is OEM VW parts. The only snag I have hit so far is whether to order the "premium" kit, which has the controller to show the movable path lines when you turn the steering wheel, or get the regular kit which only shows the proximity lines that don't move. Either way it will be OEM parts. It includes the camera, handle, wiring harness (and controller, if I get the premium) I don't anticipate removing the trim from the Tiguan will be extremely difficult. I was told that once you get past the rear seats, the wiring can be tucked under the lower trim without removing it. There is someone on the tiguan forum who has done it and is willing to share information with me regarding it.
Thanks again.
Sam
