Old 11-04-2011, 10:14 AM
Car: Bettle 2005
Smile green bean
How do you check transmission fluid level on 2005 bettle tdi engine with 6 speed tiptronic transmission
Old 11-04-2011, 10:56 AM
There is no dipstick, it's checked by measuring level with engine lukewarm.
Old 11-04-2011, 08:28 PM
Car: Bettle 2005
I change fuel filter today on 2005 bettle TDI should of fill the filter before trying to start engine of course it died and I put compress air on fuel tank and it finally started What is the procedure for changing the fuel filter ? Call VW dealer and ask them is their a way too bleed the fuel and thay said no. They said Keep CRANKING until it starts
Thanks,
Green bean
Old 11-06-2011, 10:09 PM
Car: Bettle 2005
Will today went down bad drive way & bump a rock just right it loosen the bottom plug on transmission lose some fluid. Is their light that will come on if fluid is to low? If fluid runs out that bottom plug when you loosen it with engine off is the level Ok? Also I would like to put a Trailer Hitch on the Bettle to pull a Motorcycle Camping Trailer, trailer weight is 265# to 320# would have only two people in the car.Bettle is a 2005 TDI with DSG Tiptronic. Going try too call VW dealer tomorrow see if they give any information on checking the fluid level in transmission.
Thanks,
Green Bean
Old 11-06-2011, 11:38 PM
No, level must be checked with engine running and lukewarm. Too hot or too cold and level will not be right.
Trailer should be fine but I don't know the official limits of towing. The engine/transmission can handle it but of course, refer to your owners manual for the exact specs.
