Old 01-09-2012, 11:20 AM
Default 2013 Volkswagen Jetta Hybrid pricing and projected 45 mpg EPA rating for fuel economy
The lithium-ion battery in the new Volkswagen Jetta Hybrid may be small (just 1.1 kWh), but it can pack a punch big enough to move the gas-electric to speeds up to 44 miles per hour using nothing but electrons. Throw in a combined estimated fuel efficiency rating of 45 miles per gallon and a class-leading 0-60 time of 9.0 seconds, and you've got a green Jetta that should prove to be fun out on the highway.
Of course, with only a kilowatt hour in the battery pack, you won't get very far on battery power (just 1.2 miles, VW says) and all of those electrons will come from energy that was originally gasoline (there is no plug involved here), but it's still enough of an electric powertrain for VW to call the Jetta Hybrid the "most fuel-efficient Jetta in the lineup." And it is quite a line-up, since there are now a total of five powertrains available for the Jetta, offering "a German engineered compact sedan for everyone."
The Hybrid pairs up a four-cylinder, 1.4-liter turbocharged gasoline engine with a 20-kW (27 hp) electric motor. The gas engine produces 150 horsepower and 184 pound-feet of torque between 1400 rpm and 3500 rpm. The Jetta Hybrid will become available in North America in 2012 and will be "competitively priced with other compact hybrids," VW claims. This is VW's second hybrid, following the Touareg Hybrid SUV, but the Volkswagen AG has experience with gas-electrics. The Jetta Hybrid may be the first hybrid to use a seven-speed dual-clutch automatic transmission, but the way the clutch decouples the engine from the drivetrain when the car is using just the battery for power or coasting is similar to how the Porsche hybrids do it.
As for visual changes, look for minor outside changes that improve the car's aero, like "a new front airdam, a rear diffuser, and an integrated rear spoiler."
VOLKSWAGEN REVEALS THE NO COMPROMISE, COMPACT HYBRID
The new Jetta Hybrid offers the best of all worlds, marrying performance and engaging handling with miserly combined fuel economy
World's first hybrid to use a seven-speed dual-clutch automatic transmission
Most fuel-efficient Jetta in the lineup
Drives as a full EV up to 44 mph
Fastest compact hybrid in-class with an estimated 0-60 mph in less than 9.0 seconds Competitively priced with other compact hybrids
Premium features include LED taillights and Daytime Running Lights, plus bi-xenon headlights
Jetta range extended to five different powertrains, so there‟s now a German engineered compact sedan for everyone
Wolfsburg/Herndon, VA – Volkswagen is presenting one of the world‟s most efficient automobiles at the North American International Auto Show in Detroit: the Jetta Hybrid.
Powering the all-new model is a high-tech turbocharged gasoline engine mated to a zero- emissions electric motor. While this hybrid union enables impressive driving performance with a class-leading 0-60 mph time of less than 9.0 seconds, the new Jetta Hybrid also delivers an estimated combined fuel economy figure of 45 mpg. This means that the sporty hybrid consumes about 20 percent less fuel than a similarly-powered sedan with a conventional drivetrain. In city traffic, the fuel economy advantage climbs to a little over 30 percent. In addition, the Jetta Hybrid can be driven in pure electric mode at speeds of up to 44 mph and for up to 1.2 miles depending on operating conditions.
Proven on the Autobahn
For the first time in the U.S. market, Volkswagen is using its acclaimed 1.4-liter turbocharged gasoline powerplant, which weighs just 216 pounds. The downsized four-cylinder engine develops 150 horsepower and 184 pound-feet of torque delivered from just 1400 rpm up to 3500 rpm. Combined with the 20 kW (27 hp) electric motor, the system ensures that the new Jetta Hybrid is a genuinely sporty vehicle.
High-Tech Alliance
As in the Touareg Hybrid SUV, the Jetta Hybrid features a clutch that decouples the gasoline engine from the drivetrain when in pure electric drive or coasting modes.
State-of-the-art battery: A lithium-ion battery supplies the energy to the electric motor. The compact 220-volt, 1.1 kWh battery is integrated behind the rear bench seat and weighs less than 80 lb. The battery consists of 60 individual cells with a combined energy capacity of 5 Ah. The frequency of the discharge and charge cycles in hybrid operation requires high- performance battery cooling, which is handled by a fan mounted directly on the device. The battery also has its own management system that performs safety, diagnostic, and monitoring functions as well as temperature management. The battery is disconnected when it‟s not in use or if the car is involved in a collision.
Efficient dual-clutch transmission: Power is taken to the front wheels via a seven-speed DSG® dual-clutch transmission that operates automatically and efficiently, as well as providing
super-fast shifting. Downsizing was achieved here, too: at 163 lb, the DSG transmission weighs significantly less than a conventional automatic and is also much more compact in its construction. Thanks to its lightweight drive components, the weight of the Jetta Hybrid was only increased by 221 lb despite the addition of a battery system. The car weighs in at less than 3310 lb, which is low for a hybrid vehicle.
Zero emissions electric operation: When the battery of the Jetta Hybrid is sufficiently charged, the Jetta Hybrid can be driven over a distance of up to 1.2 miles in pure electric
mode, with zero emissions. The Jetta Hybrid works as an electric vehicle up to 37 mph if the electric motor is engaged automatically or up to 44 mph if the driver presses the E-mode button to the right of the shift lever. About a third of the potential fuel savings in the Jetta Hybrid comes through electric driving.
Regenerative braking, with a wrinkle: Like other hybrid vehicles, the Jetta Hybrid uses regenerative braking, feeding kinetic energy into the battery to be stored as electrical energy
that can be used in the electric drive mode or for boosting the powertrain‟s overall performance. In the Jetta Hybrid, this is achieved more efficiently because when the driver releases the gas pedal prior to braking, the decoupling clutch disengages the engine. When the driver begins to slow down the car, all the retardation is done by the brakes rather than a combination of the brakes, drivetrain drag, and engine torque. This means that more kinetic energy is released back into the battery.
Stop and Go: The gasoline engine is stopped as soon as the car comes to a halt in city driving or stop-and-go traffic, provided that the driver presses the brake pedal and that the
battery is sufficiently charged. However, the heating and air conditioning and electrically operated comfort and convenience features, such as the audio system, continue to operate. Unlike conventional hybrid systems, when the Jetta Hybrid‟s gasoline engine is stopped, the engine is disengaged via the decoupling clutch to give a pure electric drive mode when the car moves off again-provided that the battery is sufficiently charged.
'Coasting' without the engine: As soon as the driver releases the accelerator pedal at speeds of up to 84 mph, the TSI® engine shuts down and is decoupled from the drivetrain to
eliminate driveline drag and the effects of the engine‟s torque. This results in further fuel savings.
A Hybrid with Verve
With the lever in the "S" position or in the manual shift gate, the drive system reacts to heavy throttle inputs by applying the maximum amount of propulsive power. The same applies when the driver kicks down. In these situations, the power of the electric motor and the gasoline engine combine to provide the peak output of 170 hp.
On spirited drives or when battery capacity is low, the Jetta Hybrid is powered by just the TSI engine. In certain situations, the operation of the TSI engine is also optimized for efficiency. Excess power from the engine can be used to charge the high-voltage battery via the electric motor, which acts as a generator in this case. These so-called active charging phases are interspersed with electric driving phases to realize the optimal fuel economy.
Comprehensive Information, Greater Sustainability
All relevant hybrid drivetrain information can be displayed within the multifunctional digital display on the Jetta Hybrid‟s instrument cluster. Under the „Hybrid‟ menu, the active drive mode is displayed in an energy flow diagram, and the direction of energy flow is visualized in the form of arrows. The battery charge state is shown on the same screen. Directly below the energy flow diagram is what is known as the ePower meter. This indicates the relative power of the electric motor. The ePower meter is only active in "electric driving," E-mode,TM and "Boost" operating modes.
The Power meter-an additional multifunctional display that replaces the tach on the left side of the instrument cluster-informs the driver of the momentary operating state of the Jetta Hybrid. These states are: a general readiness to drive ("Ready"); battery regeneration ("Charge"); eco-conscious driving mode ("Eco"); boosting ("Boost"); or driving only with the TSI internal combustion engine ("Off"). Electric operation, whether selected automatically or manually by the driver, is also indicated in the instruments (E-mode).
The audio system‟s display also plays a role in informing the driver of what‟s happening. When the goal is maximum economy, the audio display‟s „Zero emissions‟ menu offers a graphic of the car‟s zero emissions driving time. The zero emissions values are shown in the form of percentages in a bar diagram, where the measurement interval of one bar represents one minute of driving. A value of 100 percent means that the car was driven with zero emissions throughout the driving minute, i.e., with the TSI engine shut off. The effective time period for this is 30 minutes.
Efficiency in Design
Visually the Jetta Hybrid is distinguished by aerodynamic modifications that include a new
front airdam, a rear diffuser, and an integrated rear spoiler. As a result, the Hybrid‟s Cd is 10 percent lower than that of the stock Jetta. In addition, the Jetta Hybrid is equipped with special 15-inch alloy wheels with all-season tires optimized for low rolling resistance. Other distinguishing features include a special radiator grille where the VW logo is integrated on a blue background for the first time. The new model is also identified by Hybrid signatures on the grille, front fenders, and rear deck.
The Jetta Hybrid is the quietest car Volkswagen has even produced in the compact sedan class, thanks to a newly designed exhaust system, an acoustically optimized windshield, and thicker front side windows.
Extensive Safety and Convenience Features
Standard safety equipment for all Jetta models includes Electronic Stability Control (ESC), anti- lock brakes (ABS), and six airbags (driver and front passenger airbags, front side thorax airbags and Side Curtain Protection® airbags front and rear).
Three trims will be offered for the Jetta Hybrid. Standard features include Bluetooth® technology, LED taillights, SiriusXM® satellite radio, special 15-inch aluminum-alloy wheels, and a unique Hybrid body kit and badging. More details on trim levels will be released at a later date.
Available premium features will include bi-xenon headlights and LED Daytime Running Lights, a power driver‟s seat, heatable front seats, the RNS 315 navigation system, a rear-view camera and Volkswagen‟s exclusive Fender® Premium Audio System.
Jetta Hybrid launches in North America in 2012
The introduction of the Jetta Hybrid marks the second gasoline-electric hybrid offering by Volkswagen. The sedan, which is as sporty as it is eco-conscious, is equipped with the most advanced technology and engineering of any car Volkswagen has ever offered in this class. The 2013 Jetta Hybrid will launch in the North American market at the end of 2012.
About Volkswagen of America, Inc.
2013 Volkswagen Jetta Hybrid debuts with projected 45 mpg combined rating originally appeared on Autoblog on Mon, 09 Jan 2012
Old 01-09-2012, 06:04 PM
The real question is how much? The Prius is the gold standard for Hybrids so far and those start in the low 20s-30s loaded. Is the hybrid premium worth the additional cost vs. a regular Jetta? It's hard to compare it to diesel since diesel mpg won't be going up very much in the next 10 years, a reasonable lifetime for the car, but hybrid tech will be advancing rapidly in that same time period.
Compared to the new Ford Fusion hybrid, the Fusion looks way better (sorry), has slightly better mpg estimates, and has a plug-in option.
At least now we have a good source for HID headlight swaps and LED taillights!
Old 01-10-2012, 10:42 AM
Car: 2012 Passat SEL TDI, 2010 Jetta TDI w/DSG
Mods: Gentex auto dim mirror
This turned out better than I anticipated.
No CVT is the biggest advantage over most Hybrid competitors.
Old 01-11-2012, 01:03 AM
I gave it some thought and here are my edumacated guestimates for pricing. I put my full thoughts in my VW Jetta hybrid forum here. Based off the price premium of the VW Touareg hybrid of 5.5% in the US, the VW Jetta hybrid will be priced at $26,500-28,000. The one shown at the auto show was fully loaded with LED headlights-taillights, RNS315 navigation, full screen MFD, dual zone climatronic, fender system, and KESSY.
If that fully loaded car is priced at $26,000 they'll have a chance against the Prius. I doubt they'll have multiple trim lines but if they do, or that fully loaded car is $29,000, they'll have slow sales. You can buy a base Prius for $23,000 and fully loaded for $30,000. The Prius has a wider range of equipment on base vs. loaded so the price of the VW Jetta hybrid should be competitive at 26 but the fully loaded Prius at 30 has more equipment.
The mpg rating is what's going to matter for a hybrid. In the end, no car has been able to unseat the Prius hybrid in sales... And just to put it in perspective, a base Audi A4 is $32,500.
Old 01-12-2012, 01:27 PM
Car: 2006 Jetta TDI DSG
My question has always been.. why not a diesel-hybrid.. I know the cost is going to be the biggest issue.. but if they are fighting the MPG wars.. an electrically assisted Diesel would be unmatched.. I'm not sure what the emmision ratings are for over the road smaller HP diesel engines.. (smaller than the diesel only machines)
But I'm glad to see VW go heads up agaist the the other hybrids...
Bryan
(and yes... this used up my 1st post so I could access all the good info.. thank you everyone for posting such good info... )
Old 01-13-2012, 12:06 PM
Bryan
One problem other than cost with the hybrid/diesel equation is how long your DPF would last with the constant starts. I have measured soot buildup on a warm start vs idling and the soot buildup is considerably more on start.
Old 02-22-2012, 10:34 AM
Car: Mk5 Jetta '06
And perhaps the most important question... Why at all?
Diesel is clean. Biodiesel is easily made from just about any waste plant mass. Even sewage so it seems. Diesels easily approach the projected economy of the hybrids. Diesels don't use fuel that could otherwise be used as foodstuffs (corn-based alcohol).
So please educate me... WHY???
Old 02-22-2012, 12:12 PM
Why I didn’t mention VW’s unofficial status as the oil-burner car king? Simple: he’s heard that line hundreds of times and probably has a boilerplate response. Instead, asked him what he does—lots of people don’t know. Then, asked him make the case for VW’s latest hybrid. To add a touch of whimsy, I inquired whether he was a car guy (he turned that one around and asked my what do I think) and what youthful motoring experience proves it.
VW is proud of its diesel prowess, as demonstrated in its versatile TDI mills. “People,” however, might not go for “it,” says Michel. Frankly, there’s a limit. VW cannot expect oodles of Americans to opt for the compression ignition engine.
Therefore, VW must go forward with a hybrid power train rather than force Volks folks to buy a diesel, when seeking fuel-sipping cars. That said, VW’s clean diesels will probably pull higher highway miles per gallon in everyday use.
http://www.carnewser.com/news/107324...lts-folks-cars
Old 02-22-2012, 07:23 PM
30-40 years from now I wouldn't be surprised if most cars sold were full electric.
You have to start somewhere and if VW doesn't start now they'll have to license this technology. Not an option for one of the biggest car manufacturers.
